2019 6.0L pro cons
I'm looking at a 2019 6.0L from a wrecked chev express van 3500
Pros or cons using this engine trans in a 55 2nd series? |
Re: 2019 6.0L pro cons
Besides looks if that matters to you there are no mechanical downsides.
You get port injection which does not have carbon issues, and you get the 6 speed auto. The 6 speed really helps bring the most out of the engines. Only downsides if you want to get stupidly technical. Is a slight loss of power vs a direct injection engine. Also the loss of a 2-3 mpg of that matters to you in this situation. |
I would check into what that ECm takes to tune, a lot of the 19+ stuff requires sending the ecm in to have it unlocked before you can tune it and its not a cheap process.
#4 | |
A quick look on rockauto, and it appears the express van 6.0 still uses the e67 ECU. It doesn't look like it should be any different than any other Gen IV swap.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
I am not much on the LS swaps, but I do know the vans have the 6 speed plus port injection.
So even if the computer takes a bit more to unlock. It will be amazing versus the 4 speed. |
GM has had six-speeds for 10 years now. I sold a 6l80e from my 2010 donor. I'm using a manual trans instead.
#7 | |
It is by far the biggest upgrade to a vehicle you can make that makes everything better. In my opinion. Power to the ground, mpg, and cruisibility. I had a 07 GMC rcsb with a highly tweaked 4L65E. It is not even on the same field as my 6L80E in my 18 Silverado. The 4L80E is tough as nails, but 2 extra gears make a huge difference. The 4L65E was not really up to the task of modern bbw trucks with big hp from the factory. If I didnt have a big tunnel ram fetish at this point. I would be dropping the 4.3, and 6 speed into my next truck. Along with a 12-15 psi supercharger. So I can slap down the ecoboost fairies. |
So I did a 2016 ly6 6.0 and 6l90 out of a van in my 71 burb. It's awesome to drive and has great power with the tsp 216/220 cam I installed. The fact that the 6l90 has a really low 1st gear makes the truck feel slot lighter. Goes down the highway at 2000 rpm at 80mph and gets 20 mpg. 6 speed auto is a great choice
Okay, that's impressive! 1/2 or 3/4 ton? lifted or lowered? oversize tires? 2wd or 4wd?
71 C10 2wd lowered 3.5/4.5 3:73 rear gear with 245/45/20
#11 | |
Did you use the stock ecm E78 and harness? |
#13 |
All of the gas HD trucks from 2007(GMT900 only) and later came with 6L90E. The half ton trucks got the 6L80E in 2007(GMT900), but the 4L60E/4L65E/4L70E was an option on half ton vehicles up until 2009, when the 6 speed became the only option. So they have been in wide use for 10-12 years now.
