Old 12-28-2019, 10:21 AM   #1
Ultrasummer
What is this?
So I was looking at my carb this morning. Recently I've been curious about changing over to a Holley 2 barrel carb. Currently I have (or my best guess) a Rochester 2G. 1968 C10 with a 307 and manual 4 speed. Seems to be "mostly" original. Anyways, it's been hesitating here and there, on starts and stops. Considered a clean up and rebuild for the carb. Browsed replacing it with a new one just because. Basically considering all options. So upon taking a closer look at what I have, I notice on the back of the carb, there is a rubber hose, maybe 2 inches long, with something capping the end. I'm guessing this is some kind of vacuum line but where was it supposed to go? Is it that my simple little 307 isn't equipped for that kind of vacuum line? Is this the reason for when the vehicle hesitates?
Ultrasummer is offline   Reply With Quote
Old 12-28-2019, 10:24 AM   #2
maverickmk
maverickmk's Avatar
Re: What is this?
Do you have power brakes?
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 12-28-2019, 10:26 AM   #3
Ultrasummer
Re: What is this?
no power brakes
Old 12-28-2019, 10:28 AM   #4
maverickmk
maverickmk's Avatar
Re: What is this?
Then I would guess that is what the port is for.
Old 12-28-2019, 01:00 PM   #5
geezer#99
geezer#99's Avatar
Re: What is this?
The small short hose is likely a manifold vacuum port.
I see a vac hose by the valve cover. It could be hooked to a vac port on the front or side of the carb.
The big hose is usually used for power brakes.
You got more pics.
Be interesting to see where the big hose goes.
It might be your hesitation cause.
Old 12-28-2019, 01:05 PM   #6
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: What is this?
The big hose should go to the PCV valve. The small hose- OP, did you used to have an AIR system (SMOG pump) on your truck? That hose would have gone to the diverter valve, I suspect, if you had that system.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 12-29-2019, 09:40 AM   #7
jaros44sr
jaros44sr's Avatar
Re: What is this?
Do you have a Th350 or a 3 on the column?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-29-2019, 01:49 PM   #8
NGN
NGN's Avatar
Re: What is this?
I think it's a vacuum used to recoup emission and maybe hooks up under and to the air filter. Power brakes use the manifold vacuum fitting just a few inches back from the carb on the manifold , I also think the TH 350 auto would use the same manifold vacuum fitting with two fittings, one for the PB and one for the trans. I'm sure there's more here that can confirm.
Happy New Year
NGN is offline   Reply With Quote
