Old 12-30-2019, 03:18 PM   #1
2014sierraAT
2014sierraAT's Avatar
Illuminated bow tie retrofit
I would like to share my latest little project, I finally found myself some Chevrolet hubcaps to fit my us mag wheels. After having them for a few weeks I started looking into options to make the hood mounted bow tie match my wheels (which are the textured gold bow tie). I stumbled across the gm illuminated bow tie for the 2018 silverados. It was somewhat of a pain because of the extreme contour the nose of the hood has, I ended up having to mold some plastic on the backside to get everything to fit right. Here are some photos.
2014sierraAT is offline   Reply With Quote
Old 12-30-2019, 05:57 PM   #2
bigmac73
bigmac73's Avatar
Re: Illuminated bow tie retrofit
hell i like it, it looks good
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 12-30-2019, 05:58 PM   #3
bigmac73
bigmac73's Avatar
oh i forgot a Okie Sooner License plate would look better under it, vice the razorback
Mike
Old 12-30-2019, 08:42 PM   #4
2014sierraAT
Haha, thank you
Old 12-30-2019, 10:20 PM   #5
vitamin_c95
Looks good
1971 C20 Longhorn 350/350 "Conquistador"
vitamin_c95 is offline   Reply With Quote
Old 12-30-2019, 11:09 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Illuminated bow tie retrofit
Does the emblem lite up? Are is that the reflection off the flash of the camera? I like it either way.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-30-2019, 11:35 PM   #7
tdangle
tdangle's Avatar
I like it. Is your truck a 69 or 70? I have a 70 and the inner grill looks a little different than yours.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 12-31-2019, 12:06 AM   #8
2014sierraAT
Yes it is tied into the parking lights so it lights up whenever they are on. My truck is a 1970. There are a few differences/discrepancies between the 69/70 with both the inner and outer grilles. I have always read and heard that the painted inner grilles were only available on the 69 grilles but I have a bone stock 1970 that has the painted inner grille so I think it was just hit or miss.
Old 12-31-2019, 12:11 AM   #9
2014sierraAT
I’ve read a lot of threads on here about the differences and it seems there usually isn’t a unanimous decision either way so I’m not sure which is actually correct.
Old 12-31-2019, 12:25 AM   #10
53burb
53burb's Avatar
very cool & unique!! i think a lot of ppl may one day copy your idea....
53burb is offline   Reply With Quote
Old 12-31-2019, 05:32 AM   #11
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
X2, I'm sure that others will copy it.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 12-31-2019, 11:51 AM   #12
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I was wondering how had it would be to get a new "gold" bowtie on the front on the 71-72 grill. This looks good. I like the gold better than the blue since I'm going red.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 12-31-2019, 12:08 PM   #13
2014sierraAT
I was a little hesitant at first simply because it was different than I’m used to I guess. I really like it though and I don’t think it’s something so different that it takes away from the good looks the truck was born with, and if I ever decide to go back, it takes about 5 minutes to switch out.
Old 01-02-2020, 01:58 AM   #14
vitamin_c95
I have some bow ties from 17 silverado and camaros from swapping them out with the black ones. I'm curious now.
Old 01-03-2020, 10:17 AM   #15
1971Stepside
Almost Satisfied
Let me know what you find out.
Old 01-03-2020, 08:22 PM   #16
bigmac73
bigmac73's Avatar
what size tire and wheel are you running
Mike
Old 01-03-2020, 09:02 PM   #17
2014sierraAT
Front: 20x8
255/40/20
Rear:
22x11
285/35/22
