Cause the Chicks DIG IT!!
Heater Core hoses
Does it make a difference which way your heater core hoses are routed? Right now I got the top one on the heater core going to the water pump, and the bottom one on the core going to the intake manifold. Is this right? I didn't think there was a difference but i've seen pictures of other trucks with them going the other way?
Watch out for your cornhole !
![]() Join Date: Jun 2003
It shouldn't make much difference either way.
You'll need to check and see if you have a bi-directional heater core. They were installed on trucks that were originally sold in the southern hemisphere. (I'm kidding with you on that)
Robert Olson Transport
![]() Join Date: Oct 2002
i dont know about on your trucks but on the newer ones ya have to route them the right way and the hoses themselves are different sizes i think you have em opposite and that causes the flow not to be right and the heat to come out less
My heat does suck and i'm trying to figure out if them hoses have something to do with it. I don't really feel like pulling the heater box all apart to check to see if gaskets are with a dime.
One of your fittings should be restricted so that the water doesn't flow through too fast. Take off the hoses at the manifold and water pump and make sure one of them has a small hole instead of a full size hole. Check your running temperature also. If the thermostat has been removed, you won't get a lot of heat from the heater.
1968 Chevy C10 Longbed Fleetside |
I just bought a 4 core radiator and put a 195 degree thermostat in it. I think my gauge is off cause it reads 210-230(needle doesn't go clear back down like it should). So i know the thermostat is good but the heat just doesn't seem as warm as it should. It just really fluctuates it seems, some times its nice and warm then others it blows out cool air. The heater core i have in there is probably 4-5 yrs old cause i had to replace it before. The heater box gaskets are there I'm sure there not in the greatest of conditions but could that cause that much heat loss?
