Old 12-31-2019, 02:33 PM   #1
Austinjay
Austinjay's Avatar
Trying my hand at bucket seat upholstery and have a few questions
Hey guys - this is my first time trying to do upholstery and i have a few questions. I got my seat covers and foams new from PUI. These are for 1970 Blazer sport seats. I have attached the listing wires from the new covers to the seat foams but i have no definition in the bolsters. I have attached pictures of the seat bottom foam before and after i have attached the cover. Shouldnt the foam have more definition from the factory? it is nearly flat. Or is this what i get for buying PUI? I am nearly finished stretching the cover to the seat frame but dont want to go further if something isnt right. Any input is appreciated.
'72 K20 Ochre/white 350/350/205 4" Lift 35's
'72 GMC K10 red orange/white 400/350/205
'69 C20 Longhorn 454 TH400
'72 Blazer CST 4x4
'70 Blazer 4X4
Austinjay is offline   Reply With Quote
Old 12-31-2019, 04:31 PM   #2
Astro-Balls
Astro-Balls's Avatar
Re: Trying my hand at bucket seat upholstery and have a few questions
That looks pretty good, the only way to get more definition on the bolster is too add foam and Modify the vinyl.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 12-31-2019, 04:47 PM   #3
Austinjay
Austinjay's Avatar
Thanks for the reply. I actually reached out to a fellow instagrammer and he gave me some advice on tightening up the bolster attachment to the seat frame. Im not done with it yet but figured i would update.. its looking much better.
'72 Blazer CST 4x4
'70 Blazer 4X4
Old 12-31-2019, 04:48 PM   #4
Bigdav160
Bigdav160's Avatar
Obviously not the same upholstery but with PUI foam. Just for comparison.
Sorry, there was a large box in the passenger seat that left temporary marks
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 12-31-2019, 10:38 PM   #5
kaycee
kaycee's Avatar
It looks to me like that one seam on the bolster is the culprit , the one in between the outer edge and where your listing wire is . I am not an uhpolster but did my 63 Impala buckets with PUI foam.I belive if that seam was not there it would be golden.That edge of foam should be right on top of outer edge seam of cover. It takes some messaging to get them to set with each other, grip pinch, pull, push. Good luck and good hog ring pliers are a must
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 01-01-2020, 12:42 AM   #6
un4gvn!
un4gvn!'s Avatar
I see you went with the dark saddle also. Yeah, I had a b!%#h of a time doing my seat covers also from PUI. I waited for ever to get the covers. Every one was out of stock of the saddle. Yours are looking good.
un4gvn! is offline   Reply With Quote
Old 01-02-2020, 10:29 PM   #7
70STOVEBOLT
70STOVEBOLT's Avatar
Did you use the paperclip things to attach the listing wires to the upholstery?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 01-03-2020, 10:06 AM   #8
Austinjay
Austinjay's Avatar
I tried to use the original ones but they were too brittle. So made my own from some extra listing wire.
'72 Blazer CST 4x4
'70 Blazer 4X4
Old 01-03-2020, 10:08 AM   #9
70STOVEBOLT
You can buy them from Eckler's as Corvettes used them as well. A lot of guys use zip ties as well.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 01-03-2020, 12:44 PM   #10
kaycee
kaycee's Avatar
I used hog rings because I didnt want to make another trip to the store , all in all your seats look pretty good from here
2005 FXDWG stage3
63 IMPALA 327
Old 01-05-2020, 10:09 AM   #11
Bigdav160
Bigdav160's Avatar
I remember asking about the little paper clip thingys (I have recovered Corvette seats before) and was told there were none in the pickup truck buckets because the wire is embedded in the foam.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 01-05-2020, 10:24 AM   #12
70STOVEBOLT
Mine has the paper clips. The upholstery was not original but the foam is, so I don’t know if they were put there by the factory or not.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 01-05-2020, 01:29 PM   #13
FirstOwner69
FirstOwner69's Avatar
My '69 buckets have the paper clips... always have. Here's a picture courtesy of Classic Bowties showing the under seat wires. If you look closely you can see the clips.
EDIT: Arrow points to one of the wires, not the clips.
FirstOwner69 is offline   Reply With Quote
Old 07-08-2020, 08:49 AM   #14
70STOVEBOLT
It's been too long since I disassembled the seats, and like a dummy, I did not document the procedure. What do the paper clip things attach to on the upholstery? Is there supposed to be a wire or cord in the cover?
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
Old 07-08-2020, 04:33 PM   #15
Bigdav160
Bigdav160's Avatar
Yes, the clips would be connected to the listing wires
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 07-09-2020, 02:34 AM   #16
MattyBs71
MattyBs71's Avatar
Austin I don't think I ever saw finished pics after I gave ya that advice on Instagram.
MattyBs71 is offline   Reply With Quote
