![]() Join Date: Dec 2012
I some help spending some money for the engine
One of my projects this last December was cleaning up my flex fan and buying a new fan spacer. However, I want to instead go the routed of a solid fan with a fan clutch to reduce under hood noise, as well as safety. Can I get some recommendations for a fan and clutch from the collective knowledge here? My C10 has a 327 with a long water pump. I'm currently using this flex fan with 2" spacer. Distance from fan to radiator is 2" The truck isn't driven a lot, mostly cruising around town, with some occasional freeway driving, that I suspect will increase during the warmer months. Thank you. Attached are pics of what I have.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
![]() Join Date: Jul 2015
Re: I some help spending some money for the engine
Just looking online, FLAPS NAPA, I located a unit for a 78 3/4 ton.
Looks like if you installed it removing your spacer it would still be at the same distance. I have my fan shroud off my stock motor setup with 350 and 4 core radiator. I will go get a measurement and post back in a few. I have been wanting to do this mod. 27 bucks for the unit. I do know there is a heavy duty application available. Years ago when I worked at the FLAPS I got a HD unit for a buddy for approx. 50 bucks my cost. It retailed for almost a 100. |
20' Daredevil (Ret)
![]() Join Date: May 2003
I am on record as NOT being a fan (heh) of flex fans, so good on ya!
Lemme do some digging. I know I'd recommend a shroud, an 18" diameter 7-blade fan, and a heavy-duty fan clutch. I'll be back later with more specifics....
Thank you guys!
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Ha...lol....clever....
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
20' Daredevil (Ret)
I found my HD fan clutch at my local NAPA store. The NAPA p/n is 271303, fan clutch #2747, made by Four Seasons in Lewisville, Texas. It has performed flawlessly on my K20. I don't have it here to measure distance from pulley to radiator though, so that should be checked first.
Useful info from Hayden's website: What is the difference between a standard, heavy and severe duty fan clutch? Answer: Each fan clutch type is designed to simulate the performance of the original equipment clutch that it replaces. All fan clutches are for specific applications and should be applied only on the vehicle for which they are cataloged. Use of the incorrect fan clutch may result in poor cooling, excessive noise, reduced fuel economy or fan clutch failure. • Standard Duty Thermal: Turns the fan 50-60% of shaft speed when engaged. Used with fans with lighter pitch (1-1/2" of pitch). Flat plate impeller design with 30 sq. in. of working surface. • Heavy-Duty Thermal: Turns the fan 80-90% of the shaft speed when engaged for increased cooling. Used with deeper pitch fans (2 1/2" of pitch). Land and groove design with 47 sq. in. of working area allows higher operating RPM's. • Severe Duty Thermal: Turns the fan 80-90% of the shaft speed when engaged. Used with deeper pitch fans. (2- 1/2" of pitch). Land and groove design with 65 sq. in. of working area. Larger working surface provides cooler running and longer life expectancy.
20' Daredevil (Ret)
A bit more.... Hayden changed their site and I found a pdf with pics that clearly shows the differences between standard duty, heavy duty, and severe duty fan clutches. Easy to spot if you know what to look for.
https://www.haydenauto.com/media/567...ts_6980012.pdf
![]() Join Date: Apr 2016
That Hayden document does not have one that looks like my 1969 CST/10's clutch. Is this heavy duty? I have 7 blade fan, 2.5" fan pitch, was 4 row radiator (now 2 row Engineered Cooling Products aluminum, same radiator size as 4 row) and truck has factory A/C. When I attempt to look up a replacement clutch the only fitment matches on the auto parts store websites are for standard duty clutches.
I remember that Hayden site, very informative. I believe they are the leaders in the industry.
Following are some pics for reference. I have no cooling issues with or without the fan shroud. Have it off for evaluation of cooling performance. Stock Gen 1 350 with a short pump I believe. This should get you in a better ball part as I believe your fan it too close as I recall. My fan sits about 1/2 in 1/2 out with the stock fan shroud. |
#10 | |
What make, model, year and option???? |
#11 | |
20' Daredevil (Ret)
toolboxchev, I just saw your post. My '72 came stock with a HD fan clutch. Dunno when they started but it may have had something to do with factory A/C.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 01-01-2020 at 04:30 PM. Reason: added info |
#12 | |
#13 |
You have me curious, you used the word FLAPS twice and one of the times you said "at the FLAPS." What is that? A city or place name, reference book to look stuff up in? When I look up FLAPS NAPA on Google I see ads for mud flaps that NAPA sells.
#14 |
20' Daredevil (Ret)
Friendly Local Auto Parts Store
#15 |
#16 | |
#17 |
Who Changed This?
![]() Join Date: Jan 2013
Clutch type fans were available for trucks in '68.
https://www.napaonline.com/en/search...=semantic&se=1
#18 | |
20' Daredevil (Ret)
#19 |
![]() Join Date: Sep 2014
My 68 C20 came with a clutch fan with the original 327. I cleaned it up and it keeps the new 383 cool.
#20 |
Just poking back in to see if you spent a million!
I do like the looks of that flex fan you have, aluminum blades I presume??? I appears to be a much lighter version of the old solid heavy unit which will pull a lot of air. Pics when your done would be nice. |
