Old 01-01-2020, 08:05 PM   #1
conoco
conoco's Avatar
Dying until warm
My truck fires right up but then it dies unless i keep a little on the gas or I shift into any gear, once it is warm it doesn't die anymore. Anyone have suggestions? Timing? Idle Screw? I have a 350 rebuilt to a 383 with a holley 650 carb. Thank you.
conoco is offline   Reply With Quote
Old 01-01-2020, 08:19 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Dying until warm
adjust choke
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 01-01-2020, 08:56 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Yep, it sounds like your choke isn't working or you are not setting it before you start the truck. More information would be nice. Do you have the choke hooked up? Manual or electric choke?
If it is an electric choke you need to turn the key on, wait ten or fifteen seconds then push the accelerator pedal all the way to the floor and let up on it before you try to start the truck. If the choke is working correctly that will set the choke to the closed position and set the idle cam on the high idle position.
LockDoc
Leon
Old 01-01-2020, 08:58 PM   #4
conoco
conoco's Avatar
Originally Posted by LockDoc View Post
Yep, it sounds like your choke isn't working or you are not setting it before you start it. More information would be nice. Do you have the choke hooked up? Manual or electric choke?
If it is an electric choke you need to turn the key on, wait a minute or so then push the accelerator pedal all the way to the floor and let up on it before you try to start it. If the choke is working correctly that will set the choke to the closed position and set the cam on the high idle position.
LockDoc
it is an electric choke. I will try what you just said. I always just started it right up so that could be the problem. I just bought this truck last week and it is in great shape and I use it as a daily driver. I am just trying to tighten things up and replace what I need where I need it. i will try what you suggest. Thank you.
Old 01-01-2020, 09:01 PM   #5
LockDoc
LockDoc's Avatar
Let us know what happens. I added a little more info to my above post.
LockDoc
Leon
Old 01-01-2020, 09:33 PM   #6
truckster
truckster's Avatar
If an electric choke is working properly, you don't even need the key on to set the choke; just depress the accelerator pedal. The electric current is only used to open the choke.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 01-01-2020, 10:41 PM   #7
Sheepdip
Sheepdip's Avatar
Start with like Warren said and adjust the choke. In the cool of the morning before you try to start it and the key off....Here's how I do it
https://itstillruns.com/set-automati...e-8395654.html
Sheepdip is offline   Reply With Quote
