Old 01-01-2020, 09:23 PM   #1
White halftrack
Visor sticker oddity
Was in a salvage yard yesterday and this was on the visor. Not familiar with it.
White halftrack is offline   Reply With Quote
Old 01-01-2020, 09:26 PM   #2
White halftrack
Says 2 by 4 conversion DNE Franklin tenn
Old 01-01-2020, 10:40 PM   #3
Bandit130
Bandit130's Avatar
Re: Visor sticker oddity
Mine still has the starting procedure sticker on it. Not the 2x4 sticker.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is online now   Reply With Quote
Old 01-02-2020, 12:04 AM   #4
Dead Parrot
IF I am reading the SPID correctly, that one had the 350 diesel in it. Probably why the large starting procedure sticker. What clued me was the small square block between and above the speedo/fuel combo. On my CUCV, that has the Wait and Water in Fuel lights.
Dead Parrot is offline   Reply With Quote
Old 01-02-2020, 02:44 AM   #5
1774btcrew
1774btcrew's Avatar
Pretty sure that is a Doug Nash enterprises sticker. It looks like their logo
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 01-02-2020, 06:17 AM   #6
Danmcg
Dang, an add on 2 speed auxiliary gearbox would be cool, can you get under it to see if it's still there?
Danmcg is offline   Reply With Quote
Old 01-02-2020, 08:28 AM   #7
White halftrack
Is that what the floor handle is hooked to? Truck was originally a 2wd long box but now is a short bed? Does that dne sticker mean it had an auxiliary transmission?
The lever on floor does not have a 2wd 4 hi lo on it. Just has the driveline
symbol Did dne convert this to 4wd?
Old 01-02-2020, 08:51 AM   #8
Danmcg
my understanding is its a bolt on overdrive or dual range unit. made for 2 or 4 wheel drive.
Thats about all I know
I found this
http://www.dieselwarden.net/temp/usg...e%20manual.pdf
Old 01-02-2020, 10:00 AM   #9
b454rat
looks like a 4wd shift handle....doesn't mean anything, but never seen a 4wd diesel.
Old 01-02-2020, 10:17 AM   #10
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
NP203 transfer case conversion to part time.
https://67-72chevytrucks.com/vboard/...d.php?t=717134
This one has pdfs of a brochure:
http://67-72chevytrucks.com/vboard/s...d.php?t=378406
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '87 C10, '87 R30, 2 '89 R3500 Flatbeds
ElGracho is offline   Reply With Quote
Old 01-02-2020, 11:36 AM   #11
b454rat
Kinda makes sense now. Probly Doug Nash or whoever those abbreviations are for a part time kit for the 203.
Old 01-02-2020, 12:56 PM   #12
White halftrack
Ok. Great info. I am working on a 1978 blazer so would be good to grab that stuff.
From what I can tell off of spid that truck that has it should not be 4x4.
Thanks everyone
Old 01-02-2020, 07:49 PM   #13
Keith Seymore
Keith Seymore's Avatar
SPID indicates the truck was originally 2wd.
(Model CC10903 would decode as a Chevy 2wd 1/2 ton lwb reg cab).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-02-2020, 09:33 PM   #14
White halftrack
K
Not much on this truck makes sense. I read somewhere that the shifter knob means something. The knob on this one is the second from the left. The four tires one
Old 01-03-2020, 10:43 AM   #15
b454rat
Kinda stupid but I've seen it. Does the VIN on the spid sheet match the VIN of the truck? I found a truck in the junkyard that was a 1/2 ton. Opened glove box hoping the SPID was there, it was, and saw that is had 4.10s. Got all excited cause NEVER seen those gears in a half ton. Well, after I closed the glove box I saw it was a different color. Now in OP it looks like the door is the same color, but just thought id throw that out. But it doesn't make any sense why this truck would be converted to 4wd...
Old 01-03-2020, 12:57 PM   #16
Danmcg
I'm thinking it's C cab transplanted on a k frame
