DBW pedal in a 55.5-59 truck cab
Hi there, new member here. I am working on a 1959 Chevy Apache. I am using a 56 cab. The engine is a 2005 5.3L from a chevy Tahoe. I did get the DBW pedal setup from the donor vehicle but not sure it is gonna work in this cab. It looks pretty terrible when I hold it up to the firewall.
What DBW pedals are you using in the task force era cabs? I don't have a wiring harness yet, probably going to use Holley Terminator X Max. Thanks |
Post Whore
![]() ![]() Join Date: May 2015
Re: DBW pedal in a 55.5-59 truck cab
Welcome....
You need to keep,the pedal you have...I modified the mount on a dbw pedal to fit against the firewall and toe board...also changed the offset in the pedal arm...got any pics of your issues?
When I did my Dad's '59 Apache 5.3 DBW swap we cut the Silverado arm off at the bend, then got a donor pedal from a 80's C10. Marked the travel path so when the DBW was at WOT, the C10 pedal was just above the carpet. Tack welded in place, then rechecked before welding completely.
Sorry no pic, been 10+ years and the truck has since been sold.
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
