Old 01-03-2020, 01:27 PM   #1
dunce79
Question 61 Deluxe steering wheel on Ididit column
Has anyone been able to install a factory deluxe wheel on an Ididit column? Ididit says its a no go but just figured I'd check in here.
Looking to keep the factory wheel but ditch the old 3 on the tree column.
dunce79 is offline   Reply With Quote
Old 01-03-2020, 01:41 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: 61 Deluxe steering wheel on Ididit column
Here you go...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-03-2020, 02:16 PM   #3
dunce79
How'd u git r done?
Old 01-03-2020, 02:32 PM   #4
vin63
vin63's Avatar
If it's the Retro Series column, the spline is the same as our early steering wheels.
Old 01-03-2020, 03:17 PM   #5
dunce79
And the deluxe wheel attaches to the column without mods/adapters?
Old 01-03-2020, 03:37 PM   #6
vin63
vin63's Avatar
No adapters.
Old 01-03-2020, 04:02 PM   #7
dunce79
Any idea on the part number for that column?
Old 01-03-2020, 04:49 PM   #8
vin63
vin63's Avatar
This is the one I installed many years ago...
https://www.ididitinc.com/i-25048224...tegory:1310145
Old 01-03-2020, 05:02 PM   #9
dunce79
Great. Thanks again - much appreciated. The boss (wife) wants to keep the old wheel in her truck, so we do what we gotta do ; ).
Old 01-03-2020, 05:44 PM   #10
SkinnyG
SkinnyG's Avatar
My '61 uses a horn contact pin in the wheel, with the sliding contact ring in the column. Later everythings use a pin in the column, and the sliding contact ring in the wheel.
I intend to adapt the '61 wheel/horn to the '68 column I now have, I just haven't gotten there yet.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 01-05-2020, 11:51 AM   #11
Brad54
Brad54's Avatar
Originally Posted by vin63 View Post
Here you go...
That doesn't look like any Deluxe wheel I've seen. It's got those molded-in ribs at the sides.
And it looks a little smaller in diameter.
Anybody know the story on it?
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 01-05-2020, 12:47 PM   #12
The Rocknrod
Moderator
The Rocknrod's Avatar
http://67-72chevytrucks.com/vboard/s...d.php?t=677097
And - http://67-72chevytrucks.com/vboard/s...=288712&page=3 - welded a 61 Pontiac Ventura wheel outside to the C10 Deluxe center.
Came out great didn't it?!!
Old 01-05-2020, 08:00 PM   #13
Brad54
Brad54's Avatar
Looks fantastic!
Old 01-06-2020, 11:07 AM   #14
vin63
vin63's Avatar
Looks fantastic!
Thanks! I started to restore an original Bel Air/Deluxe steering wheel awhile back, but the only thing worth salvaging was the hub (I think the previous owner left it outside and the inner steel ring corroded). Anyway, frustrated for being sold a bill of goods and not willing to spend anymore money on what I had already spent too much on, I used a 61 Pontiac steering wheel that I reduced the diameter on many years earlier haning on my shop wall. I cut the hub out of and welded in the Bel Air steerwheel hub.
Old 01-06-2020, 04:39 PM   #15
Brad54
Brad54's Avatar
Looks awesome!
I'm probably going to do something similar, but using a Corvair steering wheel with a standard-cab horn button in the center.
Not positive it'll work with that button (so I get rid of the Corvair-emblemed center), but it's a smaller-diameter steering wheel, has the lower part of the horn ring like our Deluxe wheels, and four bands around the perimeter like the Impala wheels.
