Old 01-03-2020, 02:27 PM   #1
Lil Loafer
Stock driveshaft with big block?
I just got a 454 that I will be building soon for my 66. It wont be anything crazy, just a cam, flat top pistons, and maybe a high rise intake. My question is how much horsepower/torque will a stock 1/2 ton drive shaft take? It is a long bed so it also has the carrier bearing. Will all this be ok with a mild big block?
1966 c10
1937 Willys truck
Lil Loafer is offline   Reply With Quote
Old 01-03-2020, 11:27 PM   #2
Captainfab
60-66 Nut
Re: Stock driveshaft with big block?
The driveshaft will be just fine as long as you have the HD driveshaft and carrier bearing. If you have the light duty version, it will likely eventually end up on the ground.
Old 01-04-2020, 04:05 PM   #3
k14burb
k14burb's Avatar
If you've got a 4 speed, don't pop the clutch in low DAMHIK!
‘66 Suburban 4x4 LQ4/4L80e Dana 60’s
‘67 Camaro RS/SS convertible 350/700r4
‘74 K10 Stepside 402/TH350
k14burb is offline   Reply With Quote
Old 01-05-2020, 03:48 AM   #4
Lil Loafer
Not sure which version of the carrier bearing I have. It hangs from the top and has two bolts that will allow it to be moved forward or backward. How do I tell if its the light or heavy duty driveshaft?
I have an automatic so popping the clutch isn't a problem.
1966 c10
1937 Willys truck
Old 01-05-2020, 11:36 AM   #5
shortstep60
The one in your truck is a light duty
shortstep60 is offline   Reply With Quote
Old 01-05-2020, 10:53 PM   #6
Captainfab
60-66 Nut
I agree, you have the light duty version. It'll never hold up. If you want to convert to the HD version, I make the mounting bracket for the carrier bearing.
