01-04-2020, 01:08 AM | #1 |
1970 blower motor replacement
I got a new blower motor for my pickup.
Looks like the old one might come on out if I take the hood hinge assy off. What input do you experienced 67-72 fellas have to make go smooth? |
01-04-2020, 09:17 AM | #2 |
Re: 1970 blower motor replacement
Generally the inner fender comes off and possibly the hood hinge.
01-04-2020, 02:26 PM | #3 |
Its tight but you can do it by just removing the hood hinge. I have done it twice. 1st blower motor was from a local autoparts and really noisy.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
01-04-2020, 05:49 PM | #4 |
You can do it by just removing hinge. Did my 67 last week.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
01-05-2020, 10:45 AM | #5 |
I will second the opinion of everyone here. I will say this though, time wise it does not matter. There is one nut or bolt in the very bottom that is very difficult to get too. The inner fender well pretty much blocks access to this point.
I always pull the inner fender. It just makes for a easier time IMHO and you will be able to inspect other areas at that point normally not visible. I like to know about those unseen issues beforehand. |
01-05-2020, 11:54 AM | #6 | |
Old member
I have swapped them without removing the inner fender but it's a little harder than if you do remove it. The thread link below has some info you may need to. http://67-72chevytrucks.com/vboard/s...d.php?t=697298
01-05-2020, 03:44 PM | #7 |
As mentioned, Inner Fender and Hood Hinge. I would add to mark your hinge for position prior to removal. You will avoid having to readjust it when going back on.
01-05-2020, 06:16 PM | #8 | |
Andy, As of 2 years ago AutoZone was still stocking them as well as wiper motors. Pretty sure the blower motor was $20 bucks. I thought about investing in them! |
01-05-2020, 07:27 PM | #9 |
I have done this several times, its easy. Prop the hood on that side with a broom handle or stick. Take a small piece of a 2x4 and put it between the hinge and inner fender, take out the three hinge to fender bolts and slide the hood and hinge forward and take out the motor.
http://67-72chevytrucks.com/vboard/s...d.php?t=698292 |
01-05-2020, 09:04 PM | #10 | |
Old member
Found the motor but not the cage yet. I hope LMC has them. I'm fixing to check. Just checked LMC they have the same one listed for both AC and non AC. Cages and motors are the same part numbers. https://www.lmctruck.com/1967-72-che...r-conditioning
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. Last edited by Andy4639; 01-05-2020 at 09:10 PM. |
01-06-2020, 02:33 AM | #11 | |
