01-04-2020, 12:03 PM | #1 |
Coil Spring / Helper Spring Trailng Arms
Are the trailing arms different on the trucks equipped with the optional helper springs or is it a bolt on piece that helper springs hit on the trailing arms? Thanks.
72 C20 292 3OTT 77 GMC 2500 4x4 Longstepper 350 4sp 50 3100 ex Airforce/Town of Mendon fire truck 72 GMC 1500 2wd short stepside 250 4sp 78 GMC 2500 4x Longstepper 292 4sp 54 6400 Chevy 5 window 4 sp 2sp vac rear end Shell oil truck/dump truck (Norman) |
01-04-2020, 12:09 PM | #2 |
Re: Coil Spring / Helper Spring Trailng Arms
Trailing arma are the same,just a bolt on pad under the rear end pads held on with the U bolts
01-04-2020, 12:15 PM | #3 |
Thanks.Now I have to find them. Are they different for 1/2 3/4? Different years?
01-04-2020, 01:12 PM | #4 |
The Older Generation
Here is a picture that shows all of the parts for one side. This frame is either a SB frame or someone has cut the frame rails off. I'm betting they would be expensive to ship, they are heavy. LockDoc
01-04-2020, 02:20 PM | #5 |
I have all the parts except for the pad on the end of the trailing arm. When I bought them, I didn't know about the pads.
Do you know if the pads are different on a 1/2 or 3/4 and are they specific year? Thanks for the picture, Leon.
01-04-2020, 02:22 PM | #6 |
Good question. Those in the picture Leon posted are different from those on my '69 3/4 ton in that mine are only a single leaf vs. what appears to be 3 in Leon's picture.
01-04-2020, 02:30 PM | #7 |
The pair I have are single leaf, too.Thanks for the picture as mine is a 3/4 also.
01-04-2020, 03:39 PM | #8 |
Active Member
I don't have the picture at hand now I think it's in the assembly manual, it shows the multi leaf auxiliary spring and it's stamped discontinued, replaced by the single leaf auxiliary spring.
I've had the auxiliary spring units on both my half tons and 3/4 ton trucks and they are the same. There is a New Old stock single leaf auxiliary spring unit on eBay right now for $400 |
01-04-2020, 04:37 PM | #9 |
Thanks!!
10-01-2020, 11:54 AM | #10 |
I was trying to figure out why i had leaf springs and a coil in the rear of my truck and realized it was a "helper" spring. It looks like the pictures from others in this thread are mounted to the side of the frame...mine are mounted directly below the frame. Is this common for some setups?
1966 Ford Mustang 1969 Chevy C10 1971 Chevy C20 |
10-01-2020, 12:01 PM | #11 | |
10-01-2020, 12:03 PM | #12 | |
That looks more like an aftermarket setup, like what JC Whitney or one of those companies sold. LockDoc
10-01-2020, 03:05 PM | #13 |
This seems easier if you don't already have the leaf type helpers.
10-01-2020, 03:42 PM | #14 |
If the Trailing arm is the same is there a metal plate that fits under the axle with that bumper attached?
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
10-01-2020, 03:44 PM | #15 |
10-01-2020, 03:50 PM | #16 |
My Dad had a 68 C10, it had the multi leaf helper spring setup on it. I had a 68 C-10 that may have have a helper spring added on to it. It looked just like the factory, EXCEPT the forward end of the spring contacted the top of the axle tube,instead of the plate/cushion, like posted here...
10-01-2020, 05:55 PM | #17 | |
10-01-2020, 06:53 PM | #18 | |
Junior Member
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
