Old 01-05-2020, 12:30 AM   #1
FleetsidePaul
R.I.P. E.S.L.L.
FleetsidePaul's Avatar
My Truck Hates Hills.
My wifes friend is buying a house right around the corner from us. I was out running around doing errands today and thought I'd go check it out on my way home.
This house is at the top of the hill. With a long very steep driveway. VERY STEEP!
So I drive up the driveway and when I get to the top. My truck totally stalls out.
My truck is really very dependable. So I'm confused. It will start but it immediately dies.
Now I've got to get back down the hill. It's a common driveway with several other houses and I'm blocking it. I have a dead truck with power steering and power brakes that no longer work.
The driveway is too narrow to turn around so I put it in neutral and cross my fingers as I roll backwards trying not to hit anything. I did run over a couple of rocks (I hope they were rocks) and I didn't land in anyone's front yard.But it was a bumpy ride.
Once I got it on flat ground it started right up. Ran fine. I assume it might be the fuel pump? The carburetor wasn't getting gas at that angle I had it on?
I'm not sure. But I'm not using my truck to help my wifes friend move. It's a good excuse.
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350.
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Every day is a gift from God.
FleetsidePaul is offline   Reply With Quote
Old 01-05-2020, 12:46 AM   #2
Astro-Balls
Astro-Balls's Avatar
Re: My Truck Hates Hills.
Fuel sock picked some gunk? How much fuel in the tank?
I had a truck that would do that every time i went up a hill.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 01-05-2020, 12:54 AM   #3
truckster
truckster's Avatar
I'd check the adjustment on the float in the carburetor first.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 01-05-2020, 12:56 AM   #4
LockDoc
The Older Generation
LockDoc's Avatar
How much fuel was in it? Try backing up the hill and see what happens.
LockDoc
Leon
Old 01-05-2020, 12:56 AM   #5
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Possibly a plugged fuel filter. It happened to me with the little filter at the fuel inlet on the Q-jet. Truck would idle and run level ground or downhill, but totally crapped out & died going uphill when it needed more fuel. It would restart after maybe 15-20 minutes, then cough & die if going uphill.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 01-05-2020, 02:58 AM   #6
Sevens
Sevens's Avatar
I had this happen to me several years ago in my '78 Dodge Power Wagon (that I no longer own). It would also stall out if I floored it.
Sevens is offline   Reply With Quote
Old 01-05-2020, 03:18 AM   #7
chev-obsession
chev-obsession's Avatar
I just got my truck running after 10 years of sitting. I had similar issues. Cleaning the tank and swapping fuel filter and carb filter is How I fixed my issues.
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
