hole ID
Anyone know if this hole is used for reassmbly of front clip ?
Just considering handing my AC drier there .... dont want to make lines and then find I have to relocate the drier due to interference. ![]() small hole towards front of UPPER inner fender front and center by itself. Just above the front support rod.
FAKKY 57 PANEL BUILD |
Re: hole ID
Is that a headlight wiring pass-through?
Re: hole ID
That makes sense .....
Thinking of putting drier here ...... just dont want to have to move and create new lines ... ![]() ![]()
Re: hole ID
I'm thinking that 1project2many is correct but the TF guys will have to confirm it.
I'm thinking that these grommets go in those holes. https://www.parts123.com/parts123/yb...Z5Z5Z50000014x Or from Classic parts https://www.classicparts.com/1956-57...ctinfo/37-822/
Re: hole ID
thanks gys
cut the lines and mounted there. Looks good.
Re: hole ID
On my '57 The headlight/park light wiring was encased in a cloth loom which passed through that hole in a grommet with a single hole. When I added turn signals I added that wiring to the loom and used a new single-hole grommet.
