Driveshaft help
I have a lwb 68 c10. I had the motor and transmission out, now putting it back in and the driveshaft will not go back on the rear end. Slip yoke is bottomed out on transmission and its lacking a inch or so to go back on the rear end. The motor mounts are bolted in and good. I've tried prying, rotating rear end, jacking up on tail shaft and can not get it back on. Am I missing something? Can I just get a shorter slip yoke? I feel if I do get it back on it may push in on transmission to much if it flexes
Re: Driveshaft help
V8 installed one the front or rear holes?
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
Re: Driveshaft help
Which transmission do you have?
Re: Driveshaft help
Th350.
I believe there was only 1 set of holes. I'm looking at them and dont see different holes |
Re: Driveshaft help
When I pulled the motor I never removed the mounts from the block.
Moderator
![]() Join Date: Jun 2017
Re: Driveshaft help
I am going to assume you have a 2 piece shaft,,,,
There is a second set of slip splines on the rear shaft adjacent to the center bearing...make sure those splines will allow to second yolk to fully bottom out next to the center bearing. I have seen people grease the splines then try to push the yolk in...a pressure lock occurs preventing the slip yolk from seating fully. Its always good practice IMHO, to loosen the center bearing carrier bolts and allow the carrier to centralize with the shaft in place...this will also allow the shaft to enter the diff flanges easily. If this is a single piece shaft, jack the chassis up behind the rear end and the diff will drop and increase the available space that should allow the shaft to be installed. ![]() ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2025 Chevy Equinox ![]() ![]()
#7 | |
Re: Driveshaft help
Re: Driveshaft help
Here you go
Re: Driveshaft help
BTW this is a 327/T350
Re: Driveshaft help
It's a one piece driveshaft. I got it to go jacking up the rear of the frame and some serious prying back on the rear end. This concerns me, I dont want to ruin the tranny pump.
I'm going to post up pics of my motor mounts in a bit, I believe one may be off but I'm not positive. Thank you for the help and insight fellas. |
#11 | |
Re: Driveshaft help
Moderator
Re: Driveshaft help
There is no rear pump in a TH350.....
It looks like the one piece shaft may be too long.... Is the truck lowered from standard? Even a 2" drop will cause driveshaft issues especially with a one piece shaft.... Shafts should be measured from center of uni joint hole to center of uni joint hole with the trans yoke pulled out an inch and the truck at usual ride height. Is the shaft the one you had in the truck before you pulled the engine / trans?
#13 |
Old member
No Long wheel base trucks came with 1 piece drive shafts. If you have to pry it in your not going to last very long and every time your truck hits a bump it's going to do damage to the transmission and drive shaft. Do not drive it like this.
You need to have the truck on the ground at ride height slide the yoke all the way in then back out 1" then measure from middle of front yoke to the middle of rear yoke. Checkout the file .
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
| Bookmarks |
