Old 01-06-2020, 12:47 AM   #1
tdangle
tdangle's Avatar
Parking Brake Cable
Is there a difference between the cables depending on transmission type? In my case TH350 vs TH400. I had a TH350 and installed a 2004r which needed the trans crossmember to be in the TH400 position. I notice that now the cable center area is touching the trans mount when the parking brake is applied.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 01-06-2020, 11:32 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Parking Brake Cable
I can't tell you off the top of my head if the secondary cables are a different length or not but I know the TH400 trans cross member has a metal loop on it that the cable goes through and the TH350 doesn't. Maybe you need the loop.
I posted pictures of the differences in this thread. Post #5.
http://67-72chevytrucks.com/vboard/s....php?p=2181366
LockDoc
Leon
Old 01-06-2020, 07:37 PM   #3
tdangle
tdangle's Avatar
I would love to see a picture of the underside of the truck that has a TH400. Anyone have one?? TIA
Terry
Old 01-06-2020, 11:05 PM   #4
FirstOwner69
FirstOwner69's Avatar
Here's a picture I took from the top during tear down and one during the rebuild that may help. '69 C-20 with TH400 and 350. I don't have any pics of the underside of the truck.
FirstOwner69 is offline   Reply With Quote
