Old 01-07-2020, 10:28 AM   #1
DeadheadNM
Carpe manana
DeadheadNM's Avatar
What are the OEM hazard/direction light flashers at the fuse block?
No info in the owners manual for guidance. I've discussed with another member and believe that the direction signal flasher was a blue plastic Tung-Sol 224 flasher. What about the hazard flasher? Was this metal cased?
Anyone have original flashers still affixed to a fuse block for guidance?
Old 01-07-2020, 12:51 PM   #2
Wrenchbender Ret
Re: What are the OEM hazard/direction light flashers at the fuse block?
My 72 is 36000 mile original. It has a plastic Tung-sol 224 in the turn switch & a 552 metal flasher in the hazard warning.
I took a photo if you want me to send it.
George
Wrenchbender Ret is offline   Reply With Quote
Old 01-07-2020, 02:42 PM   #3
DeadheadNM
Carpe manana
DeadheadNM's Avatar
George
George - thank you for the reply. A photo would be great. Post if possible or I can PM you a phone number to text if that's more convenient. I'm curious what the finish and markings are on the 552. Pete
Old 01-07-2020, 03:26 PM   #4
Happy_dan
Happy_dan's Avatar
On a 68. Not sure if this helps. I can take a better picture if you need it.
1968 C-20 CST Vermillion
http://imageevent.com/happy_dan/dantoys/68c20
2019 Silverado
2012 Camaro ZL1
Happy_dan is offline   Reply With Quote
Old 01-07-2020, 06:40 PM   #5
DeadheadNM
Carpe manana
DeadheadNM's Avatar
That's helpful Dan - thanks for posting.
The "TS" embossed in the center must denote Tung-Sol
