01-07-2020, 04:01 PM | #1 |
Factory ammeters never work, why?
I’ve been around these trucks for decades and never once have I seen the needle move on a factory ammeter, ever.
Thoughts? Fix? Steve weim55 Colorado |
01-07-2020, 04:26 PM | #2 |
Re: Factory ammeters never work, why?
Replace the 2 small fuses in the lines. If they're blown, you have to figure out why
72 C10 lwb fleetside -stock 350/350 combo |
01-07-2020, 04:42 PM | #3 | |
Old member
Even when they work they move very little. You will have to watch it all the time to see it moving. It's not like a volt gauge. Very little movement unless you hook something really big amp draw on the battery.
01-07-2020, 05:47 PM | #4 |
Mine moves all the time. Like when I put the headlights on. The blinkers or start. it. Or jump start some one. It goes to the the right. When running or the left when not. Frim what I can tell it basically just tells a guy when there is load on the altinater and if it's charging with the load on it.
( second times the charm) 71 gmc c15 307 sbc 373 rear gears positrac sm 465 trans. ( not listed on spid but is original ) 94 chevy k1500 350 tbi 373 rear gears 4l60e one wheel peel. Gutless 07 gmc sierra classic rcsb 4.3 lt 5 speed w/t 04 chevy Silverado 1500 ext cab 5.3 4l60e. 81 chevy Scottsdale k10 muncie sm465 Np208 10 bolt 8.2 ( Old Green) |
01-07-2020, 06:03 PM | #5 |
Post Whore
The system isn't the best design as it requires that wiring between the battery, the alternator and the junction block near the horn be in perfect condition and of the factory sizing to allow the amp meter to work. Any changes to wiring size or poor connections changes the resistance balance and the meter will not respond as originally intended.
Count your lucky stars 71gmcC15 your one of the lucky ones.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-07-2020, 06:11 PM | #6 | |
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
01-07-2020, 06:14 PM | #7 |
Who Changed This?
Guess I'm lucky, too. If the truck has been sitting and has to crank a bit, the needle goes up about half way on the "C" side, which is about 30 Amps- if full scale is 60, and that's about what my alternator is rated at. It comes down fairly quickly, though.
01-07-2020, 06:19 PM | #8 |
When mine did not move for months I checked the two fuses, and they were BOTH blown. I replaced them, and now it moves when I turn the headlights on.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
01-07-2020, 07:17 PM | #9 |
The Older Generation
The ones in my '67, '68, and '72 work but they only move about the width of the needle in either direction. Like Andy said you have to watch really close to see them move. LockDoc
01-07-2020, 07:27 PM | #10 |
All about them K’s
Mine works as well. It the most noticeable when you first start the truck. The headlights will move it a little bit not very much. Normally after about 15 seconds on the first start the needle is back to the center of the gauge.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
01-07-2020, 07:52 PM | #11 |
[QUOTE=68 P.O.S.;8656110]Replace the 2 small fuses in the lines. If they're blown, you have to figure out why[/QUOTE
Where are the fuses you speak of? On the contrary the 64 to 66 Trucks I’ve had the ammeters work perfectly. They will sweep 3/4 of the way to the charge side after starting and settle down to the center. With the engine turned off you can turn on lights and such and it will show a significant discharge. Steve weim55 Colorado Last edited by weim55; 01-07-2020 at 07:58 PM. |
01-07-2020, 08:14 PM | #12 |
All about them K’s
They are on either corner of the core support in little black rubber fuse holders. The fuses are really small glass fuses, I believe they are 2 or 3 amp if I remember correctly.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 01-07-2020 at 08:24 PM. |
01-07-2020, 08:27 PM | #13 | ||
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. |
01-07-2020, 08:30 PM | #14 | |
The 64 - 66 trucks used the same exact ammeter circuit as 67 - 72. So when working properly, the behavior should be the same. However, 64 - 66 did not have the little 4 amp fuses protecting the meter movement and it's associated wiring. I've seen a few 64 - 66 wiring harnesses with melted ammeter wiring so I think adding the inline fuses to those years is a good idea. |
01-07-2020, 08:43 PM | #15 | |
All about them K’s
01-08-2020, 08:32 AM | #16 |
Mine works with the headlights, but otherwise, hard to notice. I would like to convert to a volt gauge one of these days. There are several threads on converting.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
01-08-2020, 11:25 AM | #17 |
The volt (battery) gauge is a great update. I did it recently..
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
01-08-2020, 11:35 AM | #18 |
A little info. The ammeter is a shunted ammeter. It measures the voltage drop across a known resistance. By Ohm's law that voltage drop indicates the amperage flowing across the resistance. That resistance is the wire from the alternator to the battery. As stated any change in the resistance of that connection affects the ammeter. So if you upgrade the alternator and change that wire accordingly the ammeter cannot be used unless you can insert the exact correct resistance and connect those two black wires that are fused across that resistor. The best possible thing is to replace that ammeter with a volt gauge conversion which is much more useful anyway. The only place an ammeter really belongs is in a stock survivor or resto.
Saskatoon, Saskatchewan Canada |
01-08-2020, 11:47 AM | #19 |
Its a Truck Thing......
I am happy that the one in old "More-Door" still works but, it does.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
01-08-2020, 12:44 PM | #20 |
Seems to be more of a novelty than an actual monitoring device. IMO
Die with memories, not dreams. Not to brag, but I don't need alcohol to make really bad decisions. 1969 GMC Short Step Side |
01-08-2020, 01:52 PM | #21 | |
Post Whore
01-08-2020, 02:50 PM | #22 |
It tells you if you are charging or discharging. Anything else really ought to be done under the hood with specialized tools, anyway, so I am satisfied with its utility.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
01-08-2020, 02:55 PM | #23 |
Mine works, but backwards. Turn the headlights on with the engine off and it swings toward the charge side. Factory stock wiring, never has been altered. I traced it out a while back and its correct. Folks bought the truck new, only thing I can figure is the meter was wired backwards when it was made.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
01-08-2020, 03:02 PM | #24 |
20' Daredevil (Ret)
Mine has worked most of the time I've owned the truck (42+ years). At some point it stopped working due to a blown fuse. A new fuse got it working again.
01-08-2020, 03:17 PM | #25 |
Mine has always worked just fine and it is interesting information but I always thought that these gauges (temperature, battery charge/discharge, and oil pressure should also have an "idiot light" on the gauge somewhere. I almost lost an engine (and it did fail a few months later) when the fan belt broke causing a very severe overheat. Who drives around monitoring these gauges constantly?
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
