67-72 Frame ID? ( 1/2 ton, 2WD)
I've done a number of searches and summarized what I found. I am by no means the expert here, just trying to put a list together. If anyone has anything they can add, Confirm, or more importantly, correct, please let me know and I'll update.
Thanks for the replies thus far ![]() I plan to go look at a couple SWB frames and wanted to have an idea up front what to look for in an attempt to ID the frames as to what years they are. Needless to say the first thing I'll look for is the partial VIN stamp, but other than that, WHAT ELSE is there to look for? My plan" I currently have a '68 LongBed C10 that I plan to convert to SWB. I will be installing drop, disk spindles, lowering springs and converting to 5lug axles (4.75 pattern). Questions: 1.) With the radiator support mounts, what specifically is different from 67 and 68, ..and 69-72? 2.) For a '68 C10, converting from LWB to SWB (noting I will be swapping out spindles) will all year frames (67-72) be equally compatible? 3.) I know the SWB wheelbase measurement is 115" (LWB is 127") but on a bare frame, where specifically would this be measured? 3.) Realizing limited pics, but based on the photos below, (I don't know the VIN# stamps yet), what year frames do you see? (Assuming both 6 lug) Frame#1: Frame#2:
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th Last edited by KevinK7; 01-08-2020 at 11:03 PM. Reason: Updated table |
Re: 67-72 Frame ID? ( 1/2 ton, 2WD)
Questions:
1.) With the radiator support mounts, what specifically is different from 67 and 68, ..and 69-72? I am interested to know this as well because I have a 72 frame and I am putting a 67 front clip on it |
I went the opposite 70 truck put a 68 frame under it. The only difference I found was the radiator support brackets are flush with the top of the frame on your 72. The 67 will be lower then the top of the frame. I had to make sure there was a dimple in the frame for the steering box . You won't have to worry about that using the newer frame. That is all I found cab mounts might be different on a 10 and 20 frame. Mine were both 1/2 ton and were the same. I looked I don't have a pic available of the front of the frame figures. Hope that helps.
If it matters my Fremont California built 67 short fleet has The VIN stamped in two places on the frame: next to the steering box and below the Rocker panel on the driver side. The frame is not dimpled for the Power steering box.
Steve weim55 Colorado |
Thanks for the info, I updated the table to reflect.
...still wondering what's different about radiator support brackets on a '68 frame.
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 ) '68 C10 50th |
![]() Join Date: Dec 1999
Pretty sure you will find the 67 and 68 core support brackets on the frame are the same. They use the same mounts and core supports.
Aparently there are plenty of early 68 frames that are not dimpled for power steering. Another difference you will find is the width of the top of the frame on the passenger side in 67 was wider because big block was not available. Discussed Here - http://67-72chevytrucks.com/vboard/s...=784551&page=2 I'm pretty sure most of them have the last part of the VIN in 2 places on the top of the drivers side frame rail. By the steering gear and under the cab. |
Here is a pic of a 68 frame mount holes are smaller.
I will update the following: - 67/68 Core support brackets (could be) the same, smaller holes than 69-72. - Early 68 frames may have no PS dimple. - VIN# stamp in two places, near PS pump and on DR frame side under cab - 67 frame wider PASS side top (Big Block not yet available) -
Were you able to complete this chart? I'm looking for the differences between a K10 frame and a C10 frame. In the 'yellow' box in the original post, you mention the differences between the two. Perhaps this post has gone quiet, but perhaps you have more information.
#10 | |
![]() Join Date: Dec 2009
![]() I am subbed for more info KevinK7 last post and visit was 09-12-2022. Maybe try sending him a PM because some members aren't getting e-mails about subscribed post.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#11 | |
![]() Join Date: Dec 2013
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=224618
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
This was a very good link, Mr. Tennessee. Thanks. I've got my frame down to nothing and sitting on sawhorses - i'll figure out a photo to add to this, and the other post. It's definitely interesting to see the curves in the frame where the coils would sit - mine is a K10 so the frame is straight there. Good post.
#13 |
![]() Join Date: Nov 2001
This is a work in progress. I love it !!!
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red |
#14 |
![]() Join Date: Feb 2009
C10 2WD came standard with rear coil springs, however leaf springs were an option.
The partial VIN is in two places, as: The LH frame rail’s top is stamped in two places with the year (1), factory location (Z) and the VIN’s serial number. One is between the carrier bearing cross member and front exhaust hanger. The other is in front of the motor mount platform. . Also, FYI The RH frame rail ‘s exterior wall is stamped 3987552 – 572 and 4-23-26, located behind the front cab mount, on my 71 SWB 2WD
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 02-08-2023 at 11:27 PM. |
