Old 01-08-2020, 12:17 AM   #1
pilotXC
Windstar 2 Speed Fan Pig Tail
Anyone know the part number for the big fan pig tail with 3 wires on the Windstar dual fans? The one I got only had 2 and the middle, high speed, is blocked and I can't pin it to wire the 2nd speed. I think I found one at O'reilly's locally but would prefer other options as this cost as much as the fan did at the junk yard... Thanks.
pilotXC is offline   Reply With Quote
Old 01-08-2020, 08:55 AM   #2
nsb29
nsb29's Avatar
Re: Windstar 2 Speed Fan Pig Tail
I am not familiar with your Fans but to the best of my knowledge each fan will have a ground wire and a hot wire The ECM has fan one and fan too in order to have high speed low-speed you need three relays fan 1 for low-speed both fans are wired in series to give you 6 V for low speed When fan 2 comes on you get 12 V to both fans if you search back to the previous page there was a thread On this very subject with wiring diagram Hope it helps
Hand made A/C vent manifolds for 64-66 trucks adapts any aftermarket A/C to OEM vent
nsb29 is offline   Reply With Quote
Old 01-08-2020, 12:11 PM   #3
cebra
The 3 wire connect is Standard Motor Products HP4540, $6 on Rock Auto. I was never able to find the 2 wire one for the other fan and just used spade connectors.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668
cebra is offline   Reply With Quote
Old 01-08-2020, 03:11 PM   #4
prodjay10
You can buy waterproof pigtails on amazon for cheap. I did this for the fuel pump because I couldn’t find the other half of the connector. For the fan I just used spades like cebra but I would like a waterproof connector on it when I have some time to work on it.
prodjay10 is offline   Reply With Quote
Old 01-11-2020, 11:00 AM   #5
pilotXC
Thanks for the help... I found that standard motors product, but a different one for $15. I decided I'd find a spade that fit and pin the existing one myself given I paid $38 for the fan, shroud, etc. I had a hard time dropping much more just for one wire. I just got some wire same gauge as the rest of the stock harness and soldered a spade connector on it, pinned and silicone'd it to the existing pig tail. Local parts stores wanted $36 for the same thing!
