Old 01-08-2020, 03:44 PM   #1
WorkinLonghorn
WorkinLonghorn's Avatar
Tach Question
My truck has the stock tach option but it was always way off. Then I put an HEI type distrib. in there and the tach just jumps around. Even the hand held multi-meter/tach that i tried hooking up just jumps around when connected to the tach terminal.
So my question is what after-market tach will fit in there and actually work with an HEI (Skip White or similar). I guess I'd have to remove the numbers from the lens.
Second question; is that old original tach repairable (can it be re-calibrated) and can it be made to work with HEI with some sort of inline adapter? Thanks -BA
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 01-08-2020, 08:58 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Tach Question
I have read that an aftermarket ignition module can make some tachs read wrong or not be stable. I have also read that some setups require a resistor in the circuit for them to read correctly. I can't remember if they were talking about stock tachs or aftermarket though. There are threads on both problems.
LockDoc
Leon
Old 01-08-2020, 10:43 PM   #3
HO455
Post Whore
HO455's Avatar
Re: Tach Question
Drop a PM to TBone1964. He is the resident expert and will have the answers you are looking for.
RIP Bob Parks.
