![]() Join Date: Jan 2018
Gearvendors Overdrive
As I begin to drive the '72 Jimmy. I'm definitely looking for a way to add an overdrive unit.
I currently have a new/rebuilt turbo 350 transmission. I have 33" tires with 410 gears. I would like to place a gear vendors unit behind the transfer case, and I would like to hear from anyone who has used gear vendors in their Jimmy, or Blazer. Please let me know if you have utilized this setup. Thanks, Pat |
![]() Join Date: Sep 2016
Re: Gearvendors Overdrive
Member cleszkie is running one on his K5 with a double cardan rear shaft, it’s a pretty cool rig, check it out.
You ever have one of those mornings where you wake up owning more trucks than you did the night before? 1972 K5 1972 K10 1967 K20 bucket truck |
Too expensive, and I would like to know how in the world anyone would be able to adapt one to a 4WD Blazer.
The most economical way to do it is to get rid of that TH350 and build up a 700R for half the cost. |
#5 | |
![]() Join Date: Mar 2003
BTW: they do have adapters for bolting one to a 205 t-case, but you have the length of the adapter and the length of the OD unit |
Carpe manana
![]() ![]() Join Date: Dec 2010
Pat - fwiw I have 33" tires, th350, and 3.73s and this combo works well for the mostly non-hwy driving I do with the Blazer. I do drive it at 65 mph or so. I also have a 700r4 in my K20 and that works well with the 4.10s. However, there is a minuscule amount of clearance between the tranny pan and the U-joint on the front shaft.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
I have the same combination and find it to be a good balance for highway, city, and off-road (not rock crawling) driving. Would I like an extra gear on the freeway? Sure, but I can buy a lot of gas for the price of an overdrive.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
#9 | |
Pat |
Thanks for the responses guys. Looks like I change the gear ratio's, or the transmission. Either ones not a lot of fun!
#11 | |
Why not consider replacing the engine as well as the transmission with something late model? You definitely won't regret it. As far as the 700, it had issues for sure, but the aftermarket industry has fixed most problems. If you get all the good parts, a 700 should last for years if not abused. The same can be said for the 4L60E. The pan clearance mentioned above is not really an issue because it's only a matter of modifying the pan a bit. Last edited by hemi43; 01-10-2020 at 11:50 AM. |
Carpe manana
Here's an example pic of how close the corner of the 700r4 gets to the U-joint: http://67-72chevytrucks.com/vboard/s...5&postcount=11
#13 | |
#14 |
Yes, I have been running a GV unit for many years in my Blazer. Not a single regret. I run it behind an SM465 and NP205 combo. Bulletproof and allows me to split all forward gears in addition to overdrive. A 700r4 is fine for light duty. But I tow heavy loads up mountain passes (27' boat and car hauler) and the GV allows me to do this without breaking a sweat or generating a huge amount of heat.
By the way, the GV mounts behind the NP 205. So, you only get the benefit of it in two-wheel drive. But I have never needed gear splitting or overdrive in four-wheel drive. Driveshaft angle is not a problem. I sourced a series 300 CV/slip yoke combo from an old Cadillac that is much shorter than a standard CV joint. The slip yoke goes into the GV unit instead of running a standard fixed CV yoke. I run 2.5 inch lift springs combined with a Dana 60 and 14 Bolt FF axles with 3" tubes which gives me something like a 4"-6" lift over stock. I run 35" tires with no issues and no trimming (see my avitar). Last edited by cleszkie; 01-10-2020 at 07:34 PM. |
#15 | |
Unfortunately, I spoke with Gear Vendors yesterday. They discouraged the use in the Jimmy/Blazer, but I told them about yours with the CV joint. They replied that it would possibly work but they couldn't guarantee no vibration. Then I told him that you were running a manual, and mine was a turbo 350. He said that could be why you were able to run it, as the manual is about 3" shorter than the automatic. He strongly discouraged the use as the 3" loss is vital in this case. Now....thinking about switching over the manual and installing an NV4500. Thanks, Pat |
#16 | |
#17 |
Ummm, yeah, about that..... Location of the drive train in the K series trucks in these years was dependent upon the front diff not hitting the oil pan with stock suspension. There were different variables regarding engine and trans combos. The t-case was always relatively close to the same spot but not fixed
#18 | |
Pat |
#19 | |
Posted via Mobile Device Last edited by hemi43; 01-11-2020 at 06:38 PM. |
#20 | |
#21 |
SM465 is shorter than a TH350 - but there is an adapter behind the 465 which is cast iron IIRC and that makes up the different I presume.
1982 K10 SWB 1987 V20 - Sold - Doh! |
#22 |
![]() Join Date: Oct 2013
Just a suggestion if looking at an NV4500 5speed. Consider a 1995 unit from a big block or diesel. Certain features of this model to consider, if not doing rock crawling. Easier install, improved shifting, gear ratios. Can order from trans rebuilder with warranty. Purchased mine a few years ago 1300.
Les |
#23 |
FYI - When I swapped my TH350 for the SM465 I found that the length of the TH350 is EXACTLY the same length as the SM 465 with adapter. No change in position of the NP205. Those dudes at GM were no dummies.
#24 | |
Thanks for the time to post on here. I do have just a few questions: I read where you utilized a 300 CV joint out of an early Cadillac. Can one still purchase one of these? Did you tilt the rear carrier up a bit? How long is your rear driveshaft? Any vibration? Thanks a bunch! Pat |
#25 |
I couldn't tell you where to find another Series 300 slip yoke/CV combo. I got mine (used) from my local drive shaft shop. I think it came out of an 80's Eldorado.
I did rotate my rear housing. Cut off the spring perches, rotated the axle and burned the perches back in. When using a CV joint, the pinion yoke on the rear axle must point straight at the transfer case output. You don't want any angle in the driveshaft on the axle end (maybe 2 degrees off to take into account slight axle wrap under load). You don't split the angle between both ends of the driveshaft like on a conventional u-joint set-up. All of the angle should be in the CV joint. I will get you a picture and some measurements. Don't have any handy. No vibration. Should be noted that I installed a traction bar. So, I get no axle wrap or other changes in the pinion angle that could cause vibration under load. |
