72 Tilt Column Shift Indicator
Hi,
Anyone ever replaced a tilt column indicator on a 1972? I dont see much on YouTube. I've got the broken turn switch out....that was my easy, but I dont see anyway to work back further through the tilting portion to get to the indicator. Anyone have any advice? Thank you. |
Re: 72 Tilt Column Shift Indicator
Sorry Guys.... I answered my own question... or at least solved my problem but I would still like to know how to get the tilt column apart???
The shift indicator just slides in the column and into the back of the indicator window. It slides in a channel so that it points to the proper gear and the back slides forward and back to allow for the tilt. Just leaving this here in case anyone has advice on getting the tilt part of the column apart? Does it involve that spring cover with cover that looks like it will accept a 1/4" drive? Thanks. |
![]() Join Date: Aug 2004
Yes, that square drive cover comes off so you can remove the spring and then the tilt pins with no pressure on them. I'm guessing you got the turn signal switch cover off so you can see the pins?
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Where can I find an indicator for a tilt column? Mine is broken. I can find non-tilt all over
#5 | |
https://gmcpauls.com/steering.htm
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
GMC Paul’s is where I get mine
