Old 01-12-2020, 02:51 PM   #1
fishmunger
fishmunger's Avatar
Can you convert 72 K10 front brakes to K20?
Without swapping complete axles? I would like to get the bigger front discs/calipers? Will the k20 parts fit on the k10 d44? Could i keep it six lug or would i have to go to 8 lug?
fishmunger is offline   Reply With Quote
Old 01-12-2020, 02:58 PM   #2
kwmech
Re: Can you convert 72 K10 front brakes to K20?
The K20 brakes are not all the much larger than the 10s. Are you having a braking problem or just want more stopping power.
And yes you wold have to go to 8 lug
Old 01-12-2020, 03:08 PM   #3
Richard
What kwmech said. 1/2t 3/4t are the same knuckle to knuckle. Have to change spindles, hubs rotors, calipers and I think the outer axle stub shafts. Have seen talk about some D44's that have thicker axle tubes.
Richard
Old 01-12-2020, 03:40 PM   #4
DeadheadNM
Carpe manana
DeadheadNM's Avatar
You could install the 3/4 t booster for added braking power. Seems like guys that have gone this route have been pleased. Might be a useful first step.
Old 01-12-2020, 04:33 PM   #5
fishmunger
fishmunger's Avatar
Thanks guys. The reason I ask is I have been looking for a k20 for a couple years. Finally came across a clean k10 that I like a lot. I want to use the truck for work and need to be able to regularly tow a heavy 22’ boat (approx 6-7k lbs). I’m wondering if the k10 will be able to stop it.
Old 01-12-2020, 05:19 PM   #6
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Does the boat trailer have brakes?
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 01-12-2020, 05:57 PM   #7
kwmech
Convert the truck to 3/4 then, use a 14b in the rear and convert the front to 8 lug. You can still use the 1/2 ton calipers on the 8 lug rotors. Rear conversion will give you a 13'' drum. Then use the 3/4 ton booster and MC
I do not own anything 1/2 ton. Years ago I had an incident with a C clip breaking and an axle shaft walking out the side of the truck. Never again--always a full float for a truck.
Old 01-12-2020, 07:01 PM   #8
fishmunger
fishmunger's Avatar
Ok so youre saying leave the front axle but convert it to 3/4 stuff, and find a full float 14 bolt from a 80s chevy? The eaton axle that comes stock in most 72k20s is ff as well?
I could put brakes on the trailer if i had to. But thats annoying cuz it sees constant saltwater use and the brakes never hold up.
