01-12-2020, 04:23 PM | #1 |
Can you convert 72 K10 front brakes to K20?
Without swapping complete axles? I would like to get the bigger front discs/calipers? Will the k20 parts fit on the k10 d44? Could i keep it six lug or would i have to go to 8 lug?
Thanks |
01-12-2020, 08:25 PM | #2 |
Re: Can you convert 72 K10 front brakes to K20?
You can but you have to go 8 lug. I did that on my Jimmy using 3/4 ton Suburban parts. From a 10 bolt yet on my Dana 44. I used the semi-float 14 bolt from the Sub as well. It is SIGNIFICANTLY stronger than the 12 bolt. It also has 13" drums for a rear brake upgrade. If you use your truck at the boat ramp, the additional performance of the parking brake is significant as well.
44 Willys MB 52 M38A1 64 Corvette Coupe 68 Camaro 'vert LT1 & TH700 69 Z/28 355 12.6's @110 69 Chevy Short Step 4 1/2"/7" drop 72 Jimmy 4WD 4spd 4" & 35's 02 GMC 2500HD 4x4 Duramax Last edited by Mike C; 01-12-2020 at 08:30 PM. |
