Old 01-12-2020, 06:11 PM   #1
twoskies
twoskies's Avatar
Jegs mini starter problem
Good Afternoon All
got a jegs mini starter part #555-10009,
had one i orginally installed January 2018, lasted 6 months, started cranking slow , then not at all
Jegs replaced with the same June of 2019, (no charge, good customer care to deal with every time ive dealt with them)
Went out today , started slow, but its been cold and ive been on call for a week so have not driven truck, went to mall, came back out, no start, only clicks
had a buddy stop and try to jump, no difference, finally got a metal rod and tapped starter, started right up
got home and tried, it did start but slow crank
does not have any binding or noise when regularly starting, sounds like a new vehicle, its usually that quiet
1972 C10, 350/4 bolt, 4 speed stick
anyone used the corvette starter with out any issues,part # if possible, might try that or ill just go back through jegs to replace
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
Old 01-12-2020, 07:36 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: Jegs mini starter problem
Suggest you upgrade to the Tuff Stuff 3 HP starter unit....bit more expensive but much better in long run
https://www.jegs.com/i/Tuff-Stuff/908/6772B/10002/-1
The 555-10009 starter is 1.9 HP....
Just my ten cents worth...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 01-12-2020, 07:37 PM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
337-1022 ac delco $100 usually from Amazon.
678-107 Dorman x2
Been good to me on 3 of my junks
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 01-12-2020, 07:56 PM   #4
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
678-107 Dorman x2
I've heard good things about Delco 1022. At this point I can say it fits nicely, pending maiden voyage.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 01-14-2020, 09:59 PM   #5
twoskies
twoskies's Avatar
talked to the good people at Jegs
Box it up and send it in, theyre going to replace the Starter
1 year warranty will start over when i get the new one
Thanks for the replies
Old 01-14-2020, 10:44 PM   #6
toolboxchev
I would look into making sure the proper distance in the starter gear to flywheel is followed.
Most after market starters come with a shim kit, instructions, and a small round gauge to measure the distance.
toolboxchev is offline   Reply With Quote
Old 01-15-2020, 01:40 PM   #7
Fldawg
Fldawg's Avatar
was having the same probelm and i added grounds and still had it, so i added a slave solnoid and hav'nt had a probelm since
"Send in the clowns the goats are loose"
Fldawg is offline   Reply With Quote
Old 01-21-2020, 07:03 PM   #8
twoskies
twoskies's Avatar
ok, so the starter has not been an issue for a few days, was going to pull it next weekend, just went out to start truck, only clicked, so as i was walking away it started to try and engage the solenoid off and on,loud whine, key was off and out of truck, after running back in and out of garage, got battery cables unhooked
starter smelled and was hot, got my tools and removed, all wires looked ok, no melted or burnt wiring
question i have is should i install the starter solenoid setup and would it have helped or eliminated this issue, might have been easier to unhook
side note: starter is being sent back for replacement
Old 01-21-2020, 07:28 PM   #9
dsy1
Also check your positive and negative cables from the battery to the starter, I just upgraded to 1/0 gauge and got better connectors after I melted the lead connectors to the battery while cranking.
dsy1 is offline   Reply With Quote
