Old 01-12-2020, 08:28 PM   #1
19stepSide72
wanna be 67
19stepSide72's Avatar
Cab seams factory mess up?
So doing some body work on my cab. As I look around the drivers side cab Seam on top has had a a piece added to it. Drivers side windshield has a large gap as well. Doors for great. Anyone else have crazy seams?
19stepSide72 is offline   Reply With Quote
Old 01-12-2020, 08:29 PM   #2
19stepSide72
wanna be 67
Re: Cab seams factory mess up?
Factory added piece.
Old 01-12-2020, 09:22 PM   #3
custom10nut
custom10nut's Avatar
Is it a “Friday” truck?
custom10nut is offline   Reply With Quote
Old 01-12-2020, 10:17 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
Trucks were considered as "utility" vehicles in those days. Visible spot welds on the exterior of the vehicle, for example, were the standard. We're spoiled these days with the plastic strips that cover the roof welds to the a/b/c pillars that used to have people leading them in or applying Bondo to cover the joint.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 01-12-2020, 10:22 PM   #5
davischevy
davischevy's Avatar
I have a cab that looks like the top skin was short, or they missed when they welded it on. You have to be on top to see it, but it is hideous.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 01-12-2020, 11:41 PM   #6
Jason Banks
Jason Banks's Avatar
There was a bend in the floor of my truck where it meets the firewall panel that I could tell by the way it was welded that was bent when put together. I drilled out the spot welds and straightened it up.
Jason Banks is offline   Reply With Quote
Old 01-13-2020, 02:10 AM   #7
67ChevyRedneck
67ChevyRedneck's Avatar
I've seen other A pillar gaps that bad (wide) before, but never seen anything like that drip rail.
New guy on the line?
A friend of mine actually has a truck where the entire PS A-pillar looks like it was stamped slightly wrong. It's a lot more "flat" than the DS (the rolled bead down the side) Truck appears to have factory paint, or it's a super old, like when truck was new-ish repair, but nothing else seems wrong or damaged.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-13-2020, 09:43 AM   #8
custom10nut
My “Body And Paint” teacher in High School told me the local Dealerships would keep him busy “Fixing and Adjusting” misalignmened Panels and doors, that came from the factory so messed up they couldn’t be opened or closed right.
Of course this was back in the 50s 60s and 70s.
Old 01-13-2020, 09:56 AM   #9
BigBird05
They would let a lot of "things" go when the demand was higher than the supply.
BigBird05 is offline   Reply With Quote
Old 01-13-2020, 12:28 PM   #10
rpmerf
rpmerf's Avatar
The factory doors on my truck, the windows frame is 1/2" lower in the back than the front.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 01-13-2020, 01:32 PM   #11
Davidf
My cab had the same or similar defect that I am currently repairing along with both inner and outer rockers as well as low door post.
Basically, the floor panel has a 1/4" or less bent lip that the firewall should engage. However, floor panel was too "short" and thus the floor panel lip prevented the floor and firewall from coming together tight. It seems the factory tried to spot weld these panels anyway and of course since the panels were about 3/16" apart, the spot welds failed and only made little dimples in the sheet metal. The factory tried to fix the issue with a few bugger welds on the outside edge. Of course the bugger welds failed and the panels were loose. I could tell there was something wrong when I pressed hard with my left foot and felt the floor give. I assumed it was rust, but now that i am fixing the rockers, the truth is out.
My fix is to straighten or flatten the floor panel lip, then drill holes to properly spot weld followed by seam sealer. Oh, and the floor panel to floor panel seam had no welds at all!
Davidf is offline   Reply With Quote
Old 01-13-2020, 05:55 PM   #12
Jason Banks
Wow DavidF yours sounds worse than mine. I have high hump and passenger side was the bent side, but the spotwelds were broke halfway across the drivers side.
Old 01-13-2020, 09:48 PM   #13
Trucknut57
Trucknut57's Avatar
My 68 cab floor at the firewall has a 3/16 to 1/4 inch gap between the floor pan and the firewall, from the driver side door the the center of the transmission cover.
Got to replace the floor pan anyways so I'll fix it then
Somehow, the idiots survive despite their best efforts to kill themselves.
- dcozzi
Trucknut57 is offline   Reply With Quote
Old 01-15-2020, 11:39 PM   #14
toolboxchev
Oh boy, here we go!
toolboxchev is offline   Reply With Quote
