Old 01-12-2020, 10:11 PM   #1
Pontitruck
Pontitruck's Avatar
NSS Connector Question
Hi Guys
I am in the process of using the factory 2 connector NSS on the 4l60e in the 65. I have researched these pages and found some good information but wanted to ask some questions. So I have I bought the harness for the NSS and the colors don't match the schematic that I pulled from my research hear. Can someone take a look at my pics and tell me if the 4 corner wires are still right based on the two pics or I need to use something else and the colors don't matter?
Pontitruck is offline   Reply With Quote
Old 01-13-2020, 12:33 PM   #2
ls1nova71
ls1nova71's Avatar
Re: NSS Connector Question
What exactly are you looking to do? The wire colors are correct on the first picture you posted as they were, not the way you have them written in. That could be maybe because you are using an aftermarket pigtail that has generic colors, not sure. The second pic you posted, I drew, and it is for the single plug NSS. If you are wanting to just use the NSS you have for back up lights, you need wires in pins C and F. For the starter relay, you would use pins G and E.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-13-2020, 12:44 PM   #3
Pontitruck
Pontitruck's Avatar
Thanks for the reply. I am using an aftermarket pigtail with the colors written down in the picture. I want to use it for BU lights and starter as you have said. I knew the second one was your drawing but thought it was the two connector style switch at the trans. Below is a pick of my harness
Old 01-23-2020, 11:07 PM   #4
truckdude239
truckdude239's Avatar
Can u post a link or part number for that plug i need to find one like that
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-24-2020, 09:31 AM   #5
Pontitruck
Pontitruck's Avatar
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F192487886971
Old 01-24-2020, 09:33 AM   #6
truckdude239
Thanks man i ordered one i am using a van tilt column and can use my factory nss
David fuller
2000 Tahoe 5.3l 378
