Old 01-12-2020, 11:41 PM   #1
LuckyScott
LuckyScott's Avatar
dash A/C center vent install help....
Got a new chrome center dash A/C vent for my 1970 truck. But didn't have the studs to install. So I got the studs friday, and can't figure it out. The studs are threaded, but the dash A/C vent is not. I know it goes into the plastic tube in the dash, but how do I put the studs in? Do I have to tap the holes or is there another piece I'm missing.
Help.....
LuckyScott is offline   Reply With Quote
Old 01-13-2020, 09:37 AM   #2
dmjlambert
dmjlambert's Avatar
Re: dash A/C center vent install help....
My center dash vent is threaded to fit the studs. I didn't get an aftermarket one, I bought a used one off the parts board here on the forum. Here is a picture from member Beelzeburb:
from this other thread
dmjlambert is offline   Reply With Quote
Old 01-13-2020, 11:04 AM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: dash A/C center vent install help....
The studs should go all the way through the black plastic tube part and then the nuts.
Outer chrome piece with studs then dash then gasket then black plastic then nuts to hold it all together.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-13-2020, 01:55 PM   #4
NorCalC20LWB
It's been a few years, but I think I had the same issue as you. Aftermarket chrome center vent without threaded holes for the studs. They did need to be tapped, although I may have just tapped them with the bolts. Definitely safest bet would be to use a real tap.
NorCalC20LWB is offline   Reply With Quote
Old 01-13-2020, 02:28 PM   #5
SIXTY9
Use a 1/4 X 20 tap, and do it with the tap handle. I used a little bit of oil on the tap.
SIXTY9 is offline   Reply With Quote
Old 01-13-2020, 07:36 PM   #6
LuckyScott
LuckyScott's Avatar
Thank you.
Old 01-13-2020, 08:37 PM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: dash A/C center vent install help....
Well I've never seen one not threaded and how I missed it I don't know but oh well you got the right info.
