wheel question
I am looking at some 19.5 wheels. Can anybody tell me if these will take regular C20 hubcaps? They do not have any nubs inside or outside of center area or clips. I realize i could put the clips on but just wondering if the hubcaps would snap in without anything?
#2 | |
![]() Join Date: Aug 2010
Re: wheel question
the picture below shows what a Chevrolet wheel looks like ('62 and later, I think), and also shows the caps which utilize a pressed in ring to engage the clips. The Correct 3/4 ton cap is the one with the thinner ring (larger opening), 1/2 tons used the wide ring version. |
Re: wheel question
The look of the 19.5 wheel, like a good bitter beer, is an acquired taste. Once you've got that flavor though, it's hard to enjoy anything else.
Re: wheel question
Thanks OEM, guess I don't need them. I have the original 16" split rims i'll get tires for. I have aluminum slots on my truck now but looking for the original look. I do like the looks of the 19.5s on the truck in the pic. I am curious what the ones for sale came on tho.
Re: wheel question
Those you saw are probably from a Ford or Dodge application. I seem to recall coming across some of the clip-less wheels during my own years-long search, and if I remember correctly they do look similar to the Chevy version.
Another option would be finding a set of the standard 17.5 wheels. One-piece like the giant 19.5's, but a bit smaller, and easier to find. Current common size tubeless tires are a significant factor when choosing period wheels. Below is the same truck wearing 17.5's |
![]() Join Date: Oct 2009
Re: wheel question
I believe it is possible to add the clips. Might be an option. Check out some of the 47-55.1 vendors.
Re: wheel question
I was kinda hopeful for the 19.5s that would've helped raise the rearend ratio. The 12.00 16.5s that i put on to help with the camper did help some as they are a little taller.
| Bookmarks |
