Qjet/Edelbrock intake factory divorce choke set up??
Installing a qjet on a edelbrock intake. Will a factory divorce choke kit work ? Thanks
Re: Qjet/Edelbrock intake factory divorce choke set up??
old intake? Picture of the intake. I'm going to say no if its newer than the mid 80's
Junior Member
![]() Join Date: Jul 2014
Just went through the same thing. Depends. Hot air or thermostatic spring? Does the intake have provision for mounting the choke? If you're using the spring type, some aftermarket intakes do have a mounting provision. On mine you could mount the later style that sits on the intake but not the earlier type that is recessed down in the crossover tube. Not sure what year the switch from inside to on top of the intake took place. My 72 uses the latter type but i had a 68 with a 327 that used the earlier recessed type. If your manifold has provision for the later style, and you don't have that style now you can switch to the later style and use on the earlier Qjet. The parts are available. Got mine at Quadrajet Parts. There are probably other sources.
Post Whore
![]() Join Date: Feb 2016
![]() Too many variables to determine otherwise..
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
2101
55-86, square bore, has a spot for the choke coil on the passenger's side, no EGR. https://www.edelbrock.com/performer-...fold-2101.html
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
I have the original Qjet sitting on a Performer aluminum intake. I removed the bimetallic choke off the original GM iron intake, it fits fine but I would suggest installing the electric choke conversion that’s available because the divorced choke never seems to warm up properly.
71 C-20 07 Magnum RT AWD |
