Old 01-15-2020, 09:45 AM   #1
skip99
skip99's Avatar
Front brake kits
About o order front brake parts for a mustang ii front, gonna go with 2 inch drop spindles and want to use gm 11“ rotors, looked at cpp stuff, any other reccommendations,,? Not wilwood or other high dollar stuff
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 01-15-2020, 10:50 AM   #2
jwhotrod
Re: Front brake kits
talk to ECI about big brake kits, they have been my go to for streetrod stuff for years. Ralph and his people are very knowledgeable and wont sell you something you don't need.
jwhotrod is offline   Reply With Quote
Old 01-15-2020, 11:02 AM   #3
Rickysnickers
Rickysnickers's Avatar
Which MII kit are you using? I ask because I went with a CPP kit that uses '09 Silverado calipers and CPP rotors, 13". I had the 11" ones on my truck when I bought it. They didn't work that well. The new ones are fabulous! https://www.classicperform.com/Store...CIWBK-P13G.htm
Old 01-15-2020, 03:10 PM   #4
skip99
skip99's Avatar
Cool, ill check eci, ccp is what ive been looking at, basically $600 for the 11” kit and spindles, the big brake kit they have for their 2” drop spindles is 11.75”, $180 more...
Tami's 51 build
Old 01-15-2020, 04:09 PM   #5
jweb
jweb's Avatar
Before I put the Wilwoods on my truck I had the Speedway 11" kit. They worked fine I just wanted more brakes when I did the LS swap
Speedway spindles $ 175: https://www.speedwaymotors.com/Speed...dles,2098.html
Speedway 11" brake kit $250 : https://www.speedwaymotors.com/Musta...M-BP,2007.html
1951 Truck, LS1/4L60
1964 Suburban, current project
jweb is offline   Reply With Quote
