![]() Join Date: Feb 2019
Bed Pads, Longbed.
My bed has developed a vibration that's driving me nuts, usually only at idle it has a harmonic vibration that will go away if I push down on the front of the bed.
I'm thinking I need new bed pads? and tighten up the bolts.. The long Steel floor Beds used pads, right??
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
Active Member
![]() Join Date: Oct 2002
Re: Bed Pads, Longbed.
That's a good question!
My restoration is still ongoing. As we were reassembling the chassis and suspension I was trying to grease and lube everything to make sure when I drive down the road it doesn't sound like a bucket of bolts, that would drive me crazy also I bought the bed pads but didn't use them. I thought that extra quarter of an inch of height on the bed was going to throw off the cab to bed body line. Hopefully someone with a completed restoration will chime in. |
![]() Join Date: Jan 2007
Not a lwb, but I recently installed 1/4” pads under the bed mounts, and also replaced the cab mounts, and the bed sits 1/2”-3/4” too high relative to the cab based on body lines. Not sure if that’s always the result, but that’s my experience with my swb...
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
Moderator
![]() Join Date: Jun 2017
I prefer to place the cab on the chassis and set the heights to get the front fenders in alignment first.
I then place the bed on the chassis and add bed pads between the mounting faces until the bed lines align with the body lines. The front fender gap to the cab is the most critical one to get right first....it is often necessary to put additional spacers under the radiator support... The bed is always the last go to on...I always use bed pads to eliminate noises and vibrations. Just MHO.... ![]() ![]() ![]() ![]()
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox ![]() ![]() ![]() |
#5 | |
Moderator
So, Steel Longbed folks, Do you have the thin rubber bushing between the bed and frame?
Here is a pic of mine..Does not appear to be any rubber between bed and frame..
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA Last edited by Astro-Balls; 01-15-2020 at 09:31 PM. |
#7 | ||
![]() Join Date: Jul 2015
I had kinda the same thing on my truck years ago. Problem is if you use them, like I do, the frame will flex. The 4 bed bolts closest to the cab were completely loose. I tried to tighten them and guess what, SNAP! Luckily I did not round out the square recess in the bed holding the carriage head.
I cut a few others out from the bottom and replaced with Stainless and Ny-lock nuts. I am getting that noise again, 9 years later. I gotta get under there again. Be careful when tightening, I found by slightly over-tightening the bed metal is fairly soft. (Heads sunk in quicker than expected) |
![]() Join Date: Jan 2018
Mine had no pads or they had worn completely away.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
No thin rubber pads on my long bed.
