Old 01-16-2020, 09:23 AM   #1
72tutone
Shift Rod Grommet/bushing
Anyone know where I can get the bushing/grommet for a factory GM tilt.
See the circle in green. There is a grommet with a metal bushing
Classicparts shows these, but I dont think this is correct
https://www.classicparts.com/1947-76...SABEgIiH_D_BwE
https://www.classicparts.com/1967-78...ctinfo/91-065/
Or, are those what I need?
Thanks!
72tutone is offline   Reply With Quote
Old 01-16-2020, 10:10 AM   #2
pickupman
pickupman's Avatar
Re: Shift Rod Grommet/bushing
Yes those are the correct ones
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 01-16-2020, 03:47 PM   #3
randy500
Thanks!
Those are the correct parts and fit perfect.
randy500 is offline   Reply With Quote
Old 01-17-2020, 08:56 AM   #4
72tutone
Thank you sir
Old 01-17-2020, 10:09 AM   #5
Andy4639
Old member
Andy4639's Avatar
Talking Re: Shift Rod Grommet/bushing
When I bought my new 71 C-10 tilt column it had that bushing installed.
Right randy500!
I used the Lakor shifter rod to hook it up to the 700-R4.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
