01-17-2020, 07:41 AM | #1 |
Best fuel pump for 71 C10
What's best for my 71 C10 350 sb manual transmission. I hate the way the electrical fuel pump sounds at times. Anyone have the pro's or cons for either. 600 series edlebrock and cammed?
01-17-2020, 12:24 PM | #2 | |
Re: Best fuel pump for 71 C10
Very easy to do, unless you have a flat lobe on the cam, or other issues prevent the usage of a stock item. |
01-17-2020, 07:14 PM | #3 |
Post Whore
Hard to go wrong with toolboxchevy's recommendation. Staying electric and being quiet involves buying the higher end pumps and regulators and then mounting the correctly. Having a return line to the tank also helps to quiet things down. My Burban has an electric pump and the regulator is noisier than the pump and then it can only be heard at idle.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
01-17-2020, 09:41 PM | #4 |
Don’t reinvent the wheel ! The original pump design is all you need for most street vehicles.
71 C-20 07 Magnum RT AWD |
01-17-2020, 11:05 PM | #5 |
If you have an edelbrock carb, their pump matches nicely with 6psi and high volume.
If you use a stock pump, you need a regulator with edelbrock carb. |
01-18-2020, 06:15 PM | #6 |
Carter M4685
4-6 psi ; works well with edelbrock carb , dont want to much pressure |
01-18-2020, 07:26 PM | #7 |
As stated above, with an Edelbrock carb, you want a pump rated for no more than 6 psi. I personally went with the Edelbrock fuel pump.
72 C10 lwb fleetside -stock 350/350 combo |
