Old 12-07-2003, 03:57 AM   #1
fast14
fast14's Avatar
fuel gauge problems
I know there was a thread on this not too long ago but I couldn't find it. My fuel gauge doesn't work. When I take the wire off the tank shouldn't the gauge go to full if it has power?? Mine doesn't move so thats why I was wondering. How do I go about checking it?? Thanks
Just a little crazy
1970 chevy full size half ton, soon to be one ton running gear, 350 turbo, 205 case, 355c.i.
fast14 is offline   Reply With Quote
Old 12-07-2003, 04:45 AM   #2
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
When you remove the wire from the sending unit the gauge should go past Full. If not the most common problem is the wire to the sending unit is grounded ,follow the wire back it should run under the drivers side sill plate ,that is probably where you will find the problem.
Good Luck
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 12-07-2003, 05:16 AM   #3
fast14
fast14's Avatar
Cool thanks, i'll check that. The gauge doesn't bounce at all, it doesn't move at all either, is that just from not having any power to it??
Just a little crazy
Old 12-07-2003, 12:30 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Correct, probably not getting power.
Pull the inst panel, and folow the 'wires' on the printed circuit. I knoe I had to jump a broken 'wire' on mine to get the fuel guage to work.
Old 12-07-2003, 01:32 PM   #5
8.1PWR
8.1PWR's Avatar
To see if your gauge and the wiring to it are working I believe that if you take the wire to the sending unit, turn your ignition to the run postion and ground it your fuel gauge should go to full.
1970 Chev C20, 2wd, LB, 350 4BBL, muncie 4spd, 4:10 limited slip.
2002 Chev 2500HD 8.1L Allison, 4X4.
1996 Chev S10 Blazer, 4X4.
2006 Jeep LJ Rubicon
8.1PWR is offline   Reply With Quote
Old 12-07-2003, 03:38 PM   #6
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Grounded goes empty, open ckt goes past full.
You can disconnect the brown wire at the fuse panel to see if it's shorted under the seat or rocker trim.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
