Old 01-17-2020, 10:46 AM   #1
mattshea125
mattshea125's Avatar
K20 with TH350/NP205
Looking for some input from anyone with a 3/4 ton 4x4 that is running a TH350 / NP205 transmission.
I have a 1978 K20 with this transmission / transfer case combo and will be putting a stock 454 big block in place of the tired 350 this year.
The transmission currently functions perfectly, but I am wondering if I should swap it to a TH400 / NP208 or just rebuild what I have so I don't have to change my whole driveline around.
The truck is used for weekend driving, picking up mulch and some towing, nothing too crazy. I rarely if ever take it off road or beat on it.
mattshea125 is offline   Reply With Quote
Old 01-17-2020, 11:50 AM   #2
kwmech
Re: K20 with TH350/NP205
T350 transmissions were not really designed for the torque of a big block. With that being said....my tree guy has a square body 3/4 ton 4x that somebody hacked a 454 into. Still has the 350/205 combo. He's been driving it that way for years. He just putts along, but he does occasionally tow a small chipper with it.
Old 01-18-2020, 12:32 PM   #3
sweetk30
sweetk30's Avatar
friend of mine has been running them for years built with ood parts and biggest clutch pack options .
he did one for me and my built 400sbc with 4.10 gears and 38" swampers on 1ton axles i run for years .
heat is the #1 killer with dirt #2 just behind it .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 01-18-2020, 01:17 PM   #4
1976gmc20
Well, I used to have one … a long time ago.
The TH350 was the weak point of the whole pickup, and I traded it off for a 4 speed.
The NP205 that you have is the strongest transfer case, though not the lowest geared.
Why don't you just rebuild the 350 V8 ???????
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
Old 01-20-2020, 12:54 PM   #5
CG
BlahBlahBlah
I think if you are wondering whether a big block 454/turbo-350/205 combo is strong enough you should contact Livrat here on the board. He ran that combo for years in his 68 GMC/Chev K20 and used the truck to haul heavy loads and pull a heavy trailer all the time.
Old 01-31-2020, 01:55 PM   #6
KyFarm
KyFarm's Avatar
If you havent all ready bought the 454, I'd do a serious checklist of all its gonna take to swap in the BB. motor , exhaust, accessories, labor to move the trans/TC back, drive shaft changes etc everything.
then price up re-build on your 350, maybe turn it into a 383 and put it right back in.
KyFarm's Build/Need help thread
1969 K-10, Short Step, (383HT/4L70E soon)-NP205
KyFarm is offline   Reply With Quote
Old 02-01-2020, 06:23 PM   #7
Jcfcamaro
Jcfcamaro's Avatar
That's exactly what I'm going to do with my 72 K10. I originally bought a 69 gmc with a 396 with power steering, A/C ect and was going to put that in ,but then decided to sell it and go with a 383. Here in the Mid west there are lots of machine shops building 383 for around 2700 with new parts.
Jcfcamaro is offline   Reply With Quote
Old 02-05-2020, 03:28 AM   #8
suburban99
suburban99's Avatar
I have a TH350/205 in my LS swapped 72 K10. The transmission shifts good and truck doesn't vibrate at 70 on the freeway. The 6.0 is around 300hp..
What most people don't realize is the TH400 takes about 15HP more to drive then the TH350..
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 02-05-2020, 12:40 PM   #9
1976gmc20
Is there some sort of established data for that sort of thing?
Reason I ask is that my observation was that a TH350 sucks off about 35% of your power compared to a manual transmission.
Old 02-06-2020, 07:50 PM   #10
sweetk30
sweetk30's Avatar
auto does eat more than man trans .
Old 02-07-2020, 10:02 AM   #11
b454rat
if your not driving it hard, I'd think you will be fine. I had a 79 Malibu that was a factory 4-speed Saginaw. I've heard and read everywhere that they were the weakest 4-speed GM built. I had a healthy 454 that I put in, guessing 400 horse. I can't drive a stick very good, more used to truck 4-speed and I have a CDL, so big truck tranny's. Well, I beat that tranny pretty good, and it would sorta hook, posi with 295/50s, but really romp in it will would spin. Tranny never even sniffled. A TH350 is definitely stronger than a Saginaw, tho it is in a heavier vehicle. But as mentioned, get a good cooler, maybe an inline filter, I think you will be fine.
Old 02-08-2020, 04:08 PM   #12
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
My truck has been running a fairly strong 402, turbo 350/205 for years.....
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 02-08-2020, 09:58 PM   #13
mongocanfly
Post Whore
mongocanfly's Avatar
Gmc20..heres some info...https://www.carsdirect.com/car-maint...-transmissions
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 02-09-2020, 12:44 PM   #14
1976gmc20
Originally Posted by mongocanfly View Post
Thanks, that makes sense. I always thought it was the slippage of the TC. The 700r4 with lock-up doesn't seem as inefficient as the old TH350. But my 5 speed pickup definitely seems to have more power than the Suburban, with basically the same engine.
