Old 01-17-2020, 04:47 PM   #1
bigguy
Dash at windshield screws
Are there supposed to be 3 to 4 large screws where the dash and windshield pinch weld meet? Popped my windshield out and saw a few screws, thought it was supposed to be spot welded all the way.
bigguy is offline   Reply With Quote
Old 01-17-2020, 05:56 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Dash at windshield screws
On my 64 the only screw you can see once the rubber is removed is for the speaker bracket.
Old 01-17-2020, 06:46 PM   #3
bigguy
This is what I'm refering to.
http://67-72chevytrucks.com/vboard/a...1&d=1579301105
Old 01-17-2020, 08:55 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
There should be 4 sheetmetal screws (2 on each side) that hold the front windshield defroster vents in place.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 01-17-2020, 10:53 PM   #5
Captainfab
60-66 Nut
This \/ \/. There should also be screws for the speaker mount as well.
