Help with leak from speedo cable
I have a little leak coming from my speed cable that goes into my transfer case. I took out the old cable and replaced it with a new one and it is still leaking. Should I change out the bullet also? What am I missing? Any help would be great. Thank you
Re: Help with leak from speedo cable
The bullet has a small seal that rides on the speedometer gear shaft. The seal can be bad and/or the gear have a groove worn. You replace the whole shootin match for less than $20.
Thank you! I will do that tomorrow. Hopefully the parts store has it. Alaska doesnt have a good track record for parts getting here lol. Thank you.
I bought mine off Ebay. It shipped out of Memphis. I do not know how that works to where you are. I think it's more of a transmission parts place thing than a auto parts store. I did the Ebay thing because the transmission suppliers near me are 30 minutes out of the way in bad parts of town. Worth $5 shipping to me.....
![]() Join Date: Apr 2016
Check out this thread:
https://67-72chevytrucks.com/vboard/...d.php?t=639106 That adapter is getting hard to come by. Last posts in that thread indicate a possible source. I went to Young’s Gear here in Fairbanks. They didn’t have any new ones but gave me 3-4 used ones and said “try em out. Keep what works best and bring the rest back. No charge.” Great guys, super helpful. That was 3 years ago. Fixed my leak.
1972 GMC K2500 Super Custom Matt |
Old member
I don't think you will find it at a parts store. Only on line are a good transmission shop.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Oops, didn't look close. I was thinking yours was a 2wd with a th350.
