01-18-2020, 07:30 PM | #1 |
Some previous owner welded the end caps on my upper control arms...
I took the suspension apart on my 1968 Chevy C10 396 shortbed fleetside truck and was in the process of trying to remove the upper control arm shafts when I noticed somebody had placed a 1/2 inch bead of weld on each of the control arm shaft end caps. They did it to both the passenger and driver side! LOL!
Was there ever a common issue with the upper control arm shaft end caps coming loose on these trucks? Anyways I guess that I will need to hit the classified here to see if anybody has a set of upper control arms for sale. Ya never know what you will find working on old cars and trucks that is for sure! |
01-18-2020, 09:38 PM | #2 |
Re: Some previous owner welded the end caps on my upper control arms...
someone probably changed them out and stripped the threads but could be someone just didn't trust they would stay put. is it welded all the way around or just tack welded ? if just tack welded they might be able to be saved
01-18-2020, 11:16 PM | #3 | |
If I nicked the lip of the control arm while trying to cut the tack weld do you think it would harm the fit or installment of the new one? |
01-18-2020, 11:30 PM | #4 |
Who Changed This?
OK, the weld is on the a-arm and the outer shell of the bushing? If, when you take it apart, and the outer bushing spins in the a-arm, if it were me, I'd buy new a-arms. If not, the nicking on the edge shouldn't change anything. Just look around at what people do with frames and steering components to modify their rides.
01-19-2020, 12:20 AM | #5 | |
01-19-2020, 01:32 AM | #6 |
Cut the weld, take them off. Replacements are cheap. Moog stuff is about 30 bucks right now, USA made even, from Jegs.
01-19-2020, 08:15 AM | #7 |
The torque #s are high for new bearing caps , The previous owner just wanted to make sure they didn't back off . I just did mine a while ago and after torquing them down I used Dykem marker on all the caps to be able to check them visually fast . after drying if you see the Dykem misaligned you know you need to address the problem . Or tack weld them . I replaced all the wear item parts with Moog from Rock auto
https://www.zoro.com/dykem-tamperpro...SABEgJrdvD_BwE
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
01-19-2020, 08:41 AM | #8 |
While you have the lower control arms off replace the stock 1/2" U bolts with the Dorman 9/16 .
01-19-2020, 08:53 AM | #9 |
it's a no brainer upgrade .
01-19-2020, 11:15 AM | #10 |
X2 on everything Grumpy said!
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
01-19-2020, 03:45 PM | #11 |
01-19-2020, 03:46 PM | #12 |
01-19-2020, 03:57 PM | #13 |
Just run a 9/16th drill bit up from the bottom to ream out the holes . easy peasy !
01-19-2020, 07:53 PM | #14 |
Great contribution Grumpy.
I will (hope I) remember this when I set-up my Front-end. .
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
01-23-2020, 01:51 PM | #15 | |
Did you use any thread locker on the upper and lower control arm shafts? Also I am not sure I understand those torque instructions? It lists the lower control arm bushings twice with different torque specs AND what exactly are they talking about New & Replace? |
01-23-2020, 02:47 PM | #16 |
Post Whore
I believe the New refers to when torquing new components and replacement refers to torquing used components. Like when a lower control arm would have been replaced with good used parts.
I have heard of this welding of the nuts before and it may have been a common practice back in the day at some shops. There is a lot of torque and not a lot threads in the arm. I would bet that failure of the threads was not that uncommon.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 Last edited by HO455; 01-23-2020 at 02:52 PM. |
01-23-2020, 03:02 PM | #17 |
I did my control arms at a friends hot rod shop and he insisted I tack weld them to keep them from backing off. After seeing how thin the threads are I understand, lot of torque and not a lot of meat to bite into.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
01-23-2020, 03:16 PM | #18 | |
01-23-2020, 04:19 PM | #19 |
Who Changed This?
Probably because of an expected difference in the amount of torque required between new and used. I'd personally expect it to be easier to thread the nuts in after they've been done once before. Might ask someone like Keith Seymour, who worked at a truck factory.
And I'd never weld them or allow someone to do so on my vehicles. The specified torque should be sufficient to hold the parts together, it's the whole point of a spec. Parts get thread locker on race cars, but that's a considerably different regime from what our trucks experience.
01-23-2020, 04:20 PM | #20 |
Grumpy is dead on about the U-bolts. I had one snap pulling a travel trailer and almost lost the whole rig.
68' with no bells or whistles unless I add'em. |
01-23-2020, 04:39 PM | #21 |
I think he's talking about both row 3 and 4 in the table being lower control arm bushing, but the torque specs are different in the 2 rows.
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
01-23-2020, 04:55 PM | #22 | |
Regarding the 2nd comment, the condition of my threads wasn't great and we didn't trust them holding only under torque hence the tacks. Next time I replace control arm bushings I will have to do the whole thing (arms + bushings) though, it was just a way to get 1 more use out of the arms rather than replace them.
01-23-2020, 05:54 PM | #23 |
No thread lock , When I did mine I had just cleaned primed and painted them and the last thing I wanted to do was throw them in a vise to mate the shafts and caps , So I installed the lower shafts onto the cross member using the new 9/16 U bolts making sure to locate the pin in the front saddle with the lower shaft and torqued them in place , Then I installed the lower control arm on to the shaft using the weight of the frame /cross member to hold it while I installed the caps alternating one turn on the front then one turn on the back until the caps bottom out on the control arm and then torque them down , Same process for the top by sliding the upper shaft onto the studs and install the shaft nuts just enough to keep the shaft from falling off the cross member , Again alternating one turn front to back until the caps are seated to the upper control arm and then torque . For me working alone this was the easiest way to get the job done and not screw up my painted control arm in a vise . Read this other thread from a few months ago . Remember to USE JACK STANDS don't ever work under any car or truck without them .
http://67-72chevytrucks.com/vboard/s...d.php?t=795425
01-23-2020, 06:02 PM | #24 |
pics
01-23-2020, 06:21 PM | #25 |
" Regarding the 2nd comment, the condition of my threads wasn't great and we didn't trust them holding only under torque hence the tacks. Next time I replace control arm bushings I will have to do the whole thing (arms + bushings) though, it was just a way to get 1 more use out of the arms rather than replace them."
This is why I used the Dykem marker to mark the caps/ control arms . It's easy to check if they need to be re torqued or tack welded after about 50 miles I go over all the suspension and check / re torque everything .
