01-19-2020, 04:16 AM | #1 |
Location: 3,018 feet above the SoCal/Mojave Desert region.
Painting frame. How did you do it?
Gonna be painting my frame. How did you do it?? What were your steps?? Info like sandpaper, wait times between coats, etc. I'm gonna be using an electric sander and wire wheel. Thanks.
01-19-2020, 10:05 AM | #2 |
Re: Painting frame. How did you do it?
I recently used a wire wheel on a grinder to clean and prep this section of my frame. I then brushed on two coats of Chassis Saver paint. It flows well but if put on too thick it will developed bubbles. Looks great from a few feet away. I plan to top coat it with some gloss rustoleum before reassembling the truck. I have read others used POR15 but I have no experience with that method.
01-19-2020, 12:23 PM | #3 |
I've heard great things about this. https://shop.masterseriesct.com/
Also heard you NEVER want to spray it, and you should wear a respirator to even brush. I've only used the primer, which applies well using foam brushes. You'd need a lot of them for an entire frame. It sands well, though I'd be surprised if there's a tougher primer available. It's used on some bridges & dumpsters as well. Goes on silver, with the option to top coat with their black or? I was going to use it on my chassis, but optioned out for more practical blasted & less practical powder coat.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
01-19-2020, 01:47 PM | #4 |
I used a combination of wire wheel, paint stripping wheel, and portable blaster with black diamond coal slag.
Sprayed with product similar to chassis saver and top coated with satin frame paint. I’ve only done from just below the back of the cab back.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
01-19-2020, 01:54 PM | #5 |
sand blasted, two coats epoxy, one coat epoxy/chassis saver satin black, two coats chassis saver satin black, and cured for a month, Quick rub with scotch bright pads, two coats satin black auto paint and three coats of satin clear.
Do it, Do it right, Do it right the first time |
01-19-2020, 03:35 PM | #6 |
The last frame I did i we sent to the powder coater, $600.00.
the only downside to that is you have to take off everything from the frame.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
01-19-2020, 04:38 PM | #7 |
Looks like our projects are at the same point in the process.
01-19-2020, 10:22 PM | #8 |
Looks like we are in about the same spot. Looking good. I am waiting on a pair of parking brake springs to finish up the rear brakes. At that point I’m gonna pull it out of the shop for pressure washing the front suspension again, wash under the cab again, and do the clr treatment on the outside. Then she will go back in the shop to pull the front apart. Paint the frame and install power steering and power disc brakes up front.
01-19-2020, 10:45 PM | #9 | |
good luck if i can answer any addtional question i will Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
01-20-2020, 06:04 PM | #10 |
Dang! If you get a rock chip it will be 1/4" deep crater.
01-20-2020, 06:52 PM | #11 |
Moderator
Hey metaldoc...love your work...but
The chassis now weighs 200 pounds more due to paint build up!!!! Assuming this will not be a daily driver when done ?
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
01-20-2020, 07:35 PM | #12 |
I wire brushed mine then used a degreaser and brush to help get anything off that was leftm. Then cleaned with brake cleaner. The paint I used was from SEM. I used their hardner as well. U can put it on with a brush or a spray gun. I liked it and its a very durable product. I accidentally hit a small section with brake cleaner and it didnt come off . POR15 is a good product but the shine will dull over time. If u use a brush, use gloves and paint it all at 1 time. I got some on my hands and it took nail polish remover and a week to get it off. Good luck.
01-26-2020, 11:48 PM | #13 |
I went this route for the current frame I am working on. Fully stripped to just two crossmembers and two rails. Powder coater charged me $500 for gloss black. Came out really nice.
Cleverly disguised as a responsible adult... |
01-27-2020, 01:21 PM | #14 |
Had it sandblasted for $120, then sprayed it all with POR-15.
The POR-15 went on nice and is still decent after 15yrs. It faded pretty bad though. Basically went from a gloss finish to a matte finish after about 5 yrs. I'd probably use it again. Good luck.
'67 c10 cst farm truck |
01-27-2020, 07:28 PM | #15 |
I sandblasted my frame and then applied MasterSeries Primer Sealer (2 coats) followed by 2 coats of AG 111 topcoat. It goes on thick and requires thinner (provided by MasterSeries) but is as tough as nails. I've since used it on crossmembers and even metal not related to my build project and have loved how it's been impervious to the snow and winter elements here.
I decided against powercoat only because I wanted to touch up if I ever had rock chips, dings etc. With any paint application (Por 15, AG) that's relatively easy to do. |
01-27-2020, 07:35 PM | #16 |
BlahBlahBlah
I got a bunch of cans of oven cleaner at the dollar store, sprayed it down, let it soak then power washed.
I brush painted it with paint (ugh I forgot the name) that is supposed to be applied to the bare metal. Its a semi gloss and is tough as nails. No need for any other kind of coats. Ive used it on two chassis now and its great. Of course I wasn't looking for a show style chassis either.
01-28-2020, 09:07 AM | #17 | |
https://www.summitracing.com/parts/sum-csumup501/ They have satin too. |
