Old 12-07-2003, 12:11 PM   #1
mocwon
Keep On Truckin'
mocwon's Avatar
Third brake light with cargo light?
Has anyone retrofitted a late model third brake light/cargo light onto the back of the cab? If so, what did it come out, what modifications were necessary and do you have pictures to post?
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 12-07-2003, 05:19 PM   #2
jhow66
jhow66's Avatar
3rdbrake light
Here how I did my with a aftermarket:
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 12-07-2003, 11:30 PM   #3
Benrs86
Benrs86's Avatar
got one off a 94-01 dodge, havent put it on yet, been on the shelf for a year, but still planning on it. thanks for reminding me, maybe i will put it in tomorrow....yeah, ill have pics in a few days.
Brandon, SD
69 GMC 1/2 ton 2wd
wide long bed with wood
3 on the tree
350 engine 4 bolt main
rv cam
AIM = Alphray04
Benrs86 is offline   Reply With Quote
Old 12-08-2003, 12:57 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You could take a stock cargo light, drill a few holes in it and pop a few lights, or even LEDs in there.
Once the lens is back on, it'll look bone stock untill you hit the woah pedal, plus, you retain the white light feature.
Old 12-08-2003, 01:09 AM   #5
chevytruck68
i installed one from a newer truck around a 94 or so ill see if i can get pics for you.
68 chevy 2wd long step lowered 67 chevy 3/4 4x4 83 gmc suburban 350 od auto 3 in body lift
chevytruck68 is offline   Reply With Quote
Old 12-08-2003, 02:57 AM   #6
imdarren
imdarren's Avatar
I dont have pix, and you may already know this, but early classic enterprises sells an LED/Cargo light that is in the original housing for our trucks. Not cheap however. I think they are $100
Would look really cool on our trucks however.
Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 12-08-2003, 02:56 PM   #7
pickup6772
pickup6772's Avatar
Thumbs up
LONGHORN, THANKS FOR SHOWING WHAT YOU DID THERE. I'VE BEEN TOYING WITH THE IDEA OF CONVERTING MY CARGO LIGHT TO A THIRD BRAKE LIGHT, BUT DIDN'T WANT TO LOSE THE CARGO. HOW HARD IS THAT TO DO, AND ABOUT HOW MUCH TIME, AND CASH?? I'M SURE THE REST OF THE GANG WOULD LIKE TO KNOW TOO
MIKE
'67 C/10 2WD LWB
'89 MERCURY GRAND MARQUIS LS
COUNTRY TILL THE DAY I DIE
pickup6772 is offline   Reply With Quote
Old 12-10-2003, 01:41 PM   #8
mocwon
Keep On Truckin'
mocwon's Avatar
That's exactly what I am looking for, a late model install with brake light and cargo light. Once you find the pictures please post along with spec on the light yopu used. Thanks!
Just Passin' Thru
Old 12-10-2003, 02:03 PM   #9
chevytruck68
i havent made it to the truck to get pics yet, but the light is from the 94 and up chevy trucks. center brakelight with 2 cargo lights on the outside. very easy to install, you might want to get a new gasket for behind it depending on the condition. the only problem is if you dont like it or want to go back to original, the problem is you have to drill 4 1 1/4 inch holes for the light sockets and one 3/4 inch hole for the wires in the cab. i like mine works great. fits the contours of the cab very good. i will try to get the pics this week yet.
Old 12-10-2003, 03:19 PM   #10
mocwon
Keep On Truckin'
mocwon's Avatar
chevytruck68
Thanks!
Just Passin' Thru
Old 12-11-2003, 01:36 AM   #11
chevytruck68
here you go, pics arent the greatest, but they should give you the idea. my camera only works good when the weather is perfect you know, sunny and no clouds
Old 12-11-2003, 01:36 AM   #12
chevytruck68
another
Old 12-11-2003, 01:38 AM   #13
chevytruck68
and the last one,
i have more pics that should be better quality but i have to go to get the roll developed the ones you see were from my cheapo digi cam.
Old 12-11-2003, 10:32 AM   #14
mocwon
Keep On Truckin'
mocwon's Avatar
chevytruck68
Thanks for the pics! That's exactly what I want to do.
Just Passin' Thru
Old 12-11-2003, 03:18 PM   #15
rambler
MOVE OVER
rambler's Avatar
Looks Good! ttt
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
