01-21-2020, 07:14 AM | #1 |
Active Member
4 speed transmission help
I recently acquired another truck, this one is a 1968, C/20 Custom Camper, 327, 4 speed.
Reverse doesn't work, does anyone have any idea what the likely problem could be ? Also where can I buy a rebuild kit for an original 68, 4 speed? |
01-21-2020, 08:17 AM | #2 |
Re: 4 speed transmission help
What transmission do you have?
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
01-21-2020, 11:49 AM | #3 |
Active Member
I don't know how to tell what 4-speed I have, can you tell me an easy way to find out?
01-21-2020, 12:01 PM | #4 |
What is the shift pattern?
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
01-21-2020, 12:05 PM | #5 |
Should be a SM 465
https://upload.wikimedia.org/wikiped...ransmition.jpg It's predecessor was the SM 420 http://www.novak-adapt.com/images/pi...21_adapter.jpg |
01-21-2020, 12:06 PM | #6 |
www.torqueking4x4.com
has parts for manual transmissions you could have a SM420...NP435...or SM465 in that year https://torqueking.com/category/1967...transmissions/
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
01-21-2020, 12:22 PM | #7 |
PTO cover on drivers side only---420
PTO cover on both sides---465 PTO cover on pass side only---435...........the 435 also has an aluminum top shifter tower |
01-21-2020, 03:18 PM | #8 |
If you have a 435 would you please tell me which frame holes the frame stands are in and post a pic of your high hump transmission cover?
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
01-21-2020, 04:14 PM | #9 |
I saw your post a while back, but didn't realize you didn't get the answer. I'll take a look tonight and get you some pics if the wifey/kiddos let me
1968 GMC C2500 Long Bed Fleetside |
01-21-2020, 04:21 PM | #10 |
Thanks, I got close...his is a big block though
01-21-2020, 07:06 PM | #11 |
Active Member
Here's a picture of the shift pattern along with the shifters position on the high hump.
Also it does have an inspection cover on both driver and passenger side, passenger side shown in picture. |
01-21-2020, 07:26 PM | #12 |
I’d say it’s a 465. The date code is what you cleaned off 3/19/6x the GM number is below it
01-21-2020, 08:35 PM | #13 |
I agree, SM465. The NP would not say GM on it. The NP435 and SM465 have same shift pattern with reverse down and to the right. The SM420 has reverse down and to the LEFT.
01-21-2020, 09:39 PM | #14 |
Active Member
Okay thanks guys that date code the last digit is "8 " it's a 68
01-21-2020, 09:51 PM | #15 |
Your welcome!
01-22-2020, 12:36 PM | #16 |
I posted my pics in your other thread to help keep this one relevant to the OP.
