01-23-2020, 01:15 PM | #1 |
Wilwood Braided Front Brake Lines
Does anyone know if these will work on a stock C10 with disc brakes? Wilwood Brake Flexline Kits 220-7056...I read all 53 reviews and it appears they may only work on Wilwood calipers or need conversion fittings which I do not want to do. Any other braided line direct replacement options? Mine are rubbing due to my drop spindles.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
01-23-2020, 03:00 PM | #2 |
Almost Satisfied
Re: Wilwood Braided Front Brake Lines
I ordered my front braided lines from Inline tube.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
01-23-2020, 03:24 PM | #3 |
$25 each, done thank you. Also, never heard of them but they have all kinds of oddball parts for our trucks.
01-23-2020, 04:18 PM | #4 | |
Almost Satisfied
01-23-2020, 07:13 PM | #5 |
The wilwood lines are 3/8 24 . got my lines from inline tube and they fit with no problem
01-24-2020, 03:15 AM | #6 |
Collector of Projects
01-24-2020, 07:41 AM | #7 |
Old member
I used Brake Hoses unlimited on my 71 disc brakes back in 2012 and so far no problems. I had them do the outer sleeve in red.
https://www.brakehosesunlimited.biz/
