Old 01-23-2020, 01:40 PM   #1
HeavyHauler
Did you put threadlocker on your upper and lower control arm shafts?
Did any of you guys use threadlocker on your upper and lower control arm shafts? It seems to be a common thing that there is worry that they can work themselves loose?
HeavyHauler is offline   Reply With Quote
Old 01-23-2020, 04:21 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Did you put threadlocker on your upper and lower control arm shafts?
I answered this in the other thread already, but I'll repeat that I do not use thread locker. Millions of trucks came from the factory without it, and until I saw it floated at this site recently, I never heard of it being done.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 01-24-2020, 01:08 PM   #3
toolboxchev
You should not need it. Factory replacement parts coming from Moog I installed last year make no mention of it in the installation instructions.
All Made in USA stuff specified that I ordered from Jegs. Good Stuff.
toolboxchev is offline   Reply With Quote
Old 01-25-2020, 11:27 PM   #4
allchevy58
allchevy58's Avatar
I didn't use threadlocker on my 71' Monte Carlo and one bolt fell out and the others were loose. Reinstalled with blue locktite and they've been fine since.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison
allchevy58 is offline   Reply With Quote
Old 01-25-2020, 11:50 PM   #5
weq92f
weq92f's Avatar
Nope.
-weq
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 01-26-2020, 01:07 AM   #6
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I used suspension grease for the cap threads and assembly lube for the hardware.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
