12-07-2003, 01:47 PM | #1 |
Firefighter
Steering box question
Do they make different ratios, or are they all the same. Meaning if I bought a new one from a parts store would my truck still steer the same as it does now? I am talking about power boxes by the way.
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
12-07-2003, 03:04 PM | #2 |
its all about the +6 inches
You have to pay some pretty big bucks from what I understand to get a faster ratio.
The later truck...80-something went to a variable ratio...but then you'll have hose fitting issues. |
12-08-2003, 04:18 PM | #3 |
Firefighter
I'm not really wanting a different ratio box, I was just wondering if they came from factory with different ratios, like say for instance if a truck came with a big block, and one with a small block would the boxes still be the same? I just didn't want to get a new box and it steer harder than the one that is on the truck now!
12-08-2003, 04:40 PM | #4 |
Resident Curmudgeon
all ps boxes installed for these trucks are the same regardless of engine/drivetrain combo.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
12-08-2003, 04:57 PM | #5 |
Firefighter
Alright! Thanks CPNE, thats the answer I was looking for!!!
12-08-2003, 09:12 PM | #6 |
BLACK AND BLUE 67-72
There is a place that can modify your original steeering box to quick ratio. They also will rebuld your original unit. http://www.powersteering.com/
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
12-08-2003, 09:46 PM | #7 |
classicperform.com (i think) its a place called cpp sells the quick ratio boxes for 300 and the regular ratio for some price
70 longbed 496/th400/Ford 9" |
12-08-2003, 09:50 PM | #8 |
Firefighter
Thanks guys!!! My old box is good other than the lower shaft where the pitman arm hooks up. The splines on the box are worn due to P/O running a used pitman arm on it, sooo it wore the splines on the shaft. I got a new pitman arm and put it on and it helped the problem a little for a while until the splines on the pitman arm wore down, so now it's like it was white line to yellow line drifting to and fro!!!
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA Last edited by BLACK AND BLUE 67-72; 12-08-2003 at 09:56 PM. |
