Old 01-25-2020, 11:54 AM   #1
Gav2606
Help identifying my front calipers
https://i1198.photobucket.com/albums...125_105908.jpg
https://i1198.photobucket.com/albums...125_110336.jpg
deas on what calipers are fitted on the front of my 68 c10?
Many thanks
Gav2606 is offline   Reply With Quote
Old 01-25-2020, 12:56 PM   #2
REDROCKER652002
Re: Help identifying my front calipers
I cannot get your pictures to load, but my son's 69 were 71 and 72 front discs. Rotors, Calipers and even the upper ball joints. If you have any part numers or casting numbers, might be a good idea to post them. My son's started with GM if that helps.
RR
REDROCKER652002 is offline   Reply With Quote
Old 01-25-2020, 03:00 PM   #3
Gav2606
The only casting numbers i can see without removing the caliper is 18007137 or the 3 maybe an 8..i was told it had s10 blazer from discs etc but im not sure it is. Got a sticky caliper so need to order parts
Old 01-25-2020, 03:02 PM   #4
Gav2606
I forgot to mention its also 5 stud now aswell.
Old 01-25-2020, 09:47 PM   #5
kwmech
Probably just stock parts from a later model. Pretty much the same stuff into the square bodies from 71-85/6 ish
