Old 12-07-2003, 04:15 PM   #1
76bonanza
76bonanza's Avatar
Hood Hinges
Going to replace my hood hinges and springs hopefully this will fix my hood raising in the back problem.
Were is the cheapest place to get these?
I saw some chrome ones for 67-72 wondering if anyone has ever seen these for our year?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 12-07-2003, 04:27 PM   #2
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
chevy duty sells em part #38-475/6 left and right for $29.95 each
therye usually cheaper than the others
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-07-2003, 05:46 PM   #3
Hipshot
hood hinge
had the same problem..took the hinge off & drilled out the large
main rivet to 1/2 inch..put in a grade 5 1/2 inch bolt with double
nuts to lock it snug. then i took a small round file & slotted the
adjustment slots another 1/4 inch..installed hood with fender
bolts loose..propped hood as high as it would go & tightened
bolts. hood closed perfect in rear!! good luck
gordy
78 GMC Stepside SB
79 Olds Toronado
"What goes around comes around"
Hipshot is offline   Reply With Quote
Old 12-07-2003, 05:55 PM   #4
76bonanza
76bonanza's Avatar
I followed you up till I propped the hood as high as it would go then tightened bolts? Dont under stand the propped hood as high as it would go?
1968 c10
lowered 3" 4"
Old 12-07-2003, 07:02 PM   #5
Hipshot
hinge
by propping the hood up and then tightening the fender bolts
you set the adjustments..when the hood closes the hinge reverses and pulls the hood down..also put folded blanket under
rear corner of hood & tie hood so it can't scratch cowl with hinge off!! good luck
gordy
78 GMC Stepside SB
79 Olds Toronado
Old 12-07-2003, 07:59 PM   #6
76bonanza
76bonanza's Avatar
Thanks for your help also do you think I should just replace hinges or springs also?
Not sure if the springs help it stay done or not?
Also I have a slight bow in hood have seen kits to fix this do they work?
1968 c10
lowered 3" 4"
Old 12-07-2003, 10:34 PM   #7
Hipshot
hinge
i would try the cure on the hinges first before replacing it would
be alot cheaper..if it works take the money you saved & buy a
good used hood. by the time you buy the kit to fix hood & have
the body work & painting done you would be way ahead!
hoods bow because the hinges have become dry & rusty from
lack of lubrication. good luck what state are you from?
gordy
78 GMC Stepside SB
79 Olds Toronado
Old 12-07-2003, 10:43 PM   #8
76bonanza
76bonanza's Avatar
missouri I just dont know if I am going to like drilling out the hinges.
1968 c10
lowered 3" 4"
Old 12-08-2003, 01:21 AM   #9
Hipshot
hinge
look at it this way.. you will be getting 60 bucks for drilling 2 holes
not bad pay in my book..good luck
gordy
78 GMC Stepside SB
79 Olds Toronado
