01-26-2020, 08:41 PM | #1 |
Heater core removal
I know there’s a few post on here already about this but I have seen many different opinions and I’m still scratching my head, so im working on my firewall cleaning it up and painting it, and I decided to delete my heater core and blower, right now I don’t have much use for it and maybe down the road I’ll invest into vintage air or something around those lines, so question is can I just put plugs on the water pump where the hose connects and the intake manifold where the other hose connects to, or do I need to keep the hose and just route it from water pump straight to manifold. I would think just plugging the ports off should have no affect but I’ve read other wise. Thanks in advance for any input.
01-26-2020, 09:01 PM | #2 |
Re: Heater core removal
I removed the hoses totally. Plugged the water pump and the intake. I never had any problems. I did run the engine for about 15 minutes after plugging the holes. I checked for leaks and made sure the air was out of the system. All was good.
1971 Chevrolet C20, Blueprint 355. Holly Street Avenger 430HP. Turbo 350 1952 Chevrolet Deluxe. Stock. True survivor with 1 paint job 1953 Buick Special. GM 355. Just a good smooth engine. |
01-26-2020, 09:04 PM | #3 |
Daron is right. Just make sure there is no air trapped in the engine.
01-26-2020, 09:09 PM | #4 |
Thanks that’s what I wanted to do but I’ve heard people say differently
01-26-2020, 11:53 PM | #5 |
What happens if there is air trapped in the engine?
'72 Chevy Custom Deluxe Highlander. Med Olive/White 350/200 ps,pb and Air Conditioning! |
01-27-2020, 09:28 AM | #6 |
If air is trapped you will have cooling issues.
